Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Apr 2008
    He most likely marked how the distributor cap is aligned before he disassembled it.
    hello,
    i don't think he marked the distributor cap. i saw him putting it back then twisting it manually. hehehe...anyway, the best thing to do is to have it checked i guess.
    Jan 2009
    Quote Originally Posted by tonyboy View Post
    hello,
    I guess you should. Anyway, by marking, I meant to say that he might have done it visually (without actually making a physical mark). He may also just relied on how the engine is running and made realtime adjustments to it.
    me drivability problems ba?
    Alam niya kung saan sparkplug nakaturo ang rotor.
    One spline off makes a big difference.
    Its taught in tech school. Alala ko tuloy yung 4k practice engine namin.
    Nov 2003
    galing naman nya if he adjusted timing without a light. if it's by feel lang then i would have it checked by a shop that has a timing light and knows what the timing for your engine should be.
    Madaling ma-adjust ang ignition timing without the help of a timing light (if you are still using contact points).
    Jul 2003
    tonyboy,
    you didn't post your car and year model to begin with. how do we know what type of distributor you are talking about then? Is it attached at the end of the camshaft and in line with the camshaft, or is it attached somewhere inclined to the engine block, where the end of the distributor shaft drives the
    oil pump? This will help to know how to set the timing, if disturbed.
    May 2011
    Quote Originally Posted by speedyfix View Post
    Today's cars have distributor less ignition that you can not mechanically adjust. There are however engines with distributors but there is no provision for mechanical ignition timing, example is the Toyota 5SFE engine. You can adjust distributor ignition timing using a scan tool, using a vacuum gauge, using a digital storage oscilloscope or by using an exhaust gas analyzer aside from the timing light.
    Quote Originally Posted by 4JGtootsie View Post
    sa batch namin SAMSON TECH 86 3K ENGINE TRADE TEST , MAGSTART LANG PASADO NA .
    Feb 2014
    Same Ignition Timing (10BTDC) from idle to 4kRPM... Sign ba to ng Stuck-up na Mechanical Advancer? Dapat bang mag advance ang Timing mark pag tumataas ang rev ng makina?
    • Idle (900rpm) 10BTDC
      4000rpm 10BTDC
      Vacuum Advancer Removed & plugged
      EE100 Corolla
      2e Engine
      1300cc
      12 valve
      CDI type distributor
    TIA!
advance/retard ignition timing
