Results 1 to 10 of 16
- Nov 2006
- 45
December 2nd, 2012 08:06 PM #1mga idol baka meron kayo ng manual ng 4k engine, baka pwede po pa post ng mga value ng mga sumusunod para maset ko sa tama..
1) ignition timing = degrees BTDC in relation to respective RPM
2) valve clearance = INTAKE & EXHAUST
3) stock jettings = pilot/slow jet, primary & secondary
December 3rd, 2012 06:03 PM #3
i doubt any engine will run at this ignition timing, not even the computer controlled ignition. some ignition system go as high as 36 degrees at higher revs. when you check igniton timing, it is set at idle speed with electronic spark advance disabled or both the vacuum and centrifugal advance disabled.please check again.
December 3rd, 2012 06:19 PM #5
try 7 degrees BTDC first and test drive, if memory serves me right it is between 7 to 9 degrees BTDC at idle with vacuum and centrifugal advancers disabled
December 3rd, 2012 06:31 PM #6
Tech:Engine/K Series/How to build a tough K motor - Rollaclub
in this website, the factory ignition timing is at 8 degrees BTDC
December 3rd, 2012 09:32 PM #8
December 4th, 2012 12:38 PM #10
i used to have this engine on my owner jeep before. bulletproof engine, as in matibay. medyo advanced ang timing ko dito, 10 BTDC. ang valve clearance ko, parehas lang ang i/e at 8. ang jet ko naman 80/95. hope this helps.
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
