Results 1 to 10 of 10
- Mar 2010
- 301
July 19th, 2019 11:13 PM #1Good Day fellow tsikots ngayon lang ako nag OL. Patulong po, nag palit na ako ng bagong Spark Plug at Fuel Filter ng 2006 Toyota Innova Gas pero palyado sya habang stop ako (bumababa ang RPM ko at ang tunog nya yun jhug jhug jhug). Tapos habang umaandar ako, may delay lang sandali at mawawala ito kapag mabili na ang takbo ko. Ano kaya ang problema?
Thannks in advance, I appreciate your tips/comments
July 19th, 2019 11:34 PM #2
- 54,195
July 19th, 2019 11:59 PM #3
- May 2011
- 481
July 22nd, 2019 03:58 PM #4At this time you probably threw the old plugs already or you can't trace which one came from which cylinder. When you check the newer plugs, mark each one from which cylinder it came from, take pictures and post them. Do not clean them before taking pictures. As an experienced technician, I mark the plugs for diagnosis and analysis.
The used spark plugs are ones of the best engine performance or drivability diagnostic tool.
- Jun 2005
- 3,774
July 22nd, 2019 04:35 PM #5Have the throttle body and MAF sensor cleaned.
Ganyan ang symptoms ng maduming TB sa mga toyora vvti engines
Sent from my MI MAX 2 using Tapatalk
- Mar 2010
- 301
July 24th, 2019 03:23 PM #6[QUOTE=dr. d;3092931]if your old plugs are still available, ibalik nyo and see if the problem disappears.
if it disappears, "then you have your answer".
yes, i know it's simplistic, but it is also costs next to nothing.[/QUOTE}]
Nagawa ko na na ok sya. Kaya lang after 3 days bumalik ulit.
- Mar 2010
- 301
- Mar 2010
- 301
July 24th, 2019 03:29 PM #8
- May 2011
- 481
July 25th, 2019 05:52 PM #9Where are the pictures of the spark plug tips?
We can be guessing your mystery and you might end up changing good parts.
- May 2019
- 312
July 30th, 2019 02:47 PM #10Did you check the new spark plug’s gap before putting them? Is the check engine light on? Was it running fine before changing the plugs?
Will wonders never cease with Motolite? Ha ha.
