Results 211 to 220 of 383
May 11th, 2020 01:40 PM #211
That's right! It claims "heavy duty" and yet it can't allow high current to pass through for that "push start" that you need.
I always bring both, a jumper cable and the power bank. Should the power bank fail, I have the cables. And the said cables are "custom made", rated as a welding cable. I had enough of those "heavy duty" cables.
Unfortunately, I couldn't resist the request of a friend when he asked for the cables...
May 11th, 2020 01:54 PM #212
I recommend you buy both! I bought it one at a time, so that it won't feel expensive.
[emoji3]
Just like with tools, I bought a set a few years ago. Then, a torque wrench. If the need arises, I'll buy a digital torque wrench. And since replacing a tire is tiresome for me, I plan on buying a cheap cordless impact wrench. Should it fail, then I do the "tiresome" method.
May 11th, 2020 02:20 PM #213
- Nov 2009
- 3,507
May 11th, 2020 02:27 PM #214^A 2-port car lift is in my wishlist should this ecq be extended.
It is more common nowadays to replace bat 2-3yrs or after the bat warranty expire to avoid downtime, but because of expensiveness people tend to wait until the certain death of the battery. My advise is to monitor the battery health so that you won't be needing extra weight and space for tools inside the car. That way also you may be able to predict when the battery would fail and when to bring those tools for jump-starting.
May 11th, 2020 02:52 PM #215
- Sep 2006
- 2,746
May 11th, 2020 07:25 PM #216
- Sep 2006
- 2,746
May 11th, 2020 07:35 PM #217Thanks for the advice sir, I read here you own a ctek smart charger, how about for the jump starter, which brand did you get?
Gf never understood why us boys find it quite satisfying to own handyman tools, I just point at her shoes and bags everytime she tells me that.
May 11th, 2020 08:37 PM #218
For the jump starter, I bought the one from Ace hardware. I find it expensive considering that there are cheaper ones online. However, there's no way to test it. The first time I saw it, I asked the guy to demonstrate it on my car. The funny part, he connected it without disconnecting the negative terminal.
[emoji3]
Anyways, I helped him out by showing him and explaining that for it to be tested properly, the negative terminal must be disconnected, then connect the jump starter and start the car.
It was my second purchase as I gave the other one to my brother. I think I need to make a third purchase in the near future since my son took it. And that will be next year because I have a relatively new battery.
I have used it several times, mostly to other motorists. With that, I am confident to recommend that brand from Ace hardware.
Surely, those jump starters online are also good. It's just that I haven't tried it yet and because there are times I travel in the middle of the night, I can't take the risk of trying other brands.
Most often than not, I buy things not from my regular salary but from other incomes like hazard pay and bonus. These are not part of our daily budget so that my wife and I won't have any adjustments with these kinds of purchases.
- 54,188
May 11th, 2020 08:51 PM #219those jumper wires from ace or handyman.
they all heat up when used.
the insulation is very thick.
you can just imagine, if the insulation is very thick, and yet they feel hot after using,
the very thin wire inside must be glowing-hot!
when i jump-started my innova, the jumper wires got really hot.
jump-starting the sedan or hatch, the wires did not get as hot.
i should really assemble my own, using stranded cable wire.
what would be the minimum gauge, kaya? i still have to roll it up into a small-ish bundle.Last edited by dr. d; May 11th, 2020 at 09:01 PM.
May 11th, 2020 09:01 PM #220
Is it just me or have traffic worsened this week compared to pre-Holy Week? Is it because people...
Traffic!
