Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Aug 2012
    I have 2011 Innova E, meron akong foglight and want to install it by DIY, tanong lang po kung meron bang abang na linya para sa foglight at abang na wire para sa switch sa may lower dashboard? Meron din po bang makukuhanan ng wiring diagram nito? Thanks.
    Bro.,- ang OEM switch ng foglights ng Innova ay kasama sa mga switches ng park/head lights.....
    Not sure with the newer models though.
    16.5K:weathermanf3:
    Aug 2012
    16.5K:weathermanf3:
    Ok sir tnks, pero meron na bang abang na linya para kabitan ng foglight?
    May 2010
    Just make a separate switch for it bro.
    Aug 2012
    since sabi kasi ni sir CVT kasama sa switch ng park light, hinahanap ko kasi baka meron nang abang na wire sa may bandang likod ng headlight para dun na i-connect direkta yung foglight. Tiningnan ko kasi sa fuse box sa engine, may sarili na syang fuse na 15A, kaya malamang meron na rin syang abang na wire.
    Jul 2010
    Yung DLAA na foglights for toyota innova may kasama nang wiring, switch, fuse and relay. So installation na lang kailangan.
    Oct 2009
    ang alam ko pag orig at sa casa binili ang foglamp complete set na..
    relay switch at diagram wiring..
    ikakabit nalang..
    Aug 2012
    meron kayang pwedeng mag post or mag send through e-mail ng wiring diagram. Thanks
    Dec 2012
    I'm also installing (DIY) fog light for my innova E 2012. There is already a pre-installed wiring. I'm hoping that someone have a wiring diagram of Innova to help me install the switch. I couldn't figure out where to tap. The switch has 3 wires. I think number 1 will be for 12V power supply, number 2 will be for ground (or negative) and number 3 will be to the relay. My problem is where to tap the 12V fog light power supply and relay.
    Jun 2012
    ^ Have you figured out how to connect the fog lamps? The relay will drive them.
Innova foglight
