Results 1 to 10 of 10
    Apr 2004
    my ae111's power antenna blags once it is fully rolled up or down. What seems to be the problem? anong pwedeng kong gawin?
    thanks in advance
    is it still original or aftermarket power antenna?
    Apr 2004
    Quote Originally Posted by ghosthunter
    sir, its the original power antenna. I was just thinking if it needs some lubrication or what.
    baka may naipit na gears. yup, you can try lubing it up para walang sabit. yan kasi sakit ng mga power antenna eh. kaya ako, pinadisconnect ko na akin ever since nasira and pinagawa na twice...
    sometimes the plastic "wick" gear has worn out and needs to be replaced. But the likely culprit is a "sensor" (actually a contact point) inside the antenna motor which detects either full up or full down position. Might be dirty only.
    baka nasira na yung antenna rod gear (its plastic)....you might have to check if they sell replacement antenna rod.
    Kung DIYer ka, madali lang kalasin yan....I was able to "adjust" my power antenna na nabali sa base...I removed the sira and now it's shorter but still works.
    Dec 2003
    yeah like the civic ek's power antenna, always broke down. durable ones are the nissans i think, my ex cefiro's antenna was still working like new and silent too even after 70k kms, and our ex 98 frontier's power antenna was faultless.
    Apr 2004
    thanks guys, i will lube it when i get back from dagupan. Am planning to use wd40.
    Quote Originally Posted by BlueBimmer
    The Japan market based Nissan antennas are okay ('97-'00 Cefiro, Frontier, etc)... the ones from the Taiwan market suck big time ('01 Sentra Grandeur).
    Quote Originally Posted by carlocaraddict
    try mo KY Jelly pre... mas tatagal ang lub... parang grasa....
help on AE111's power antenna
