Results 21 to 30 of 50
June 28th, 2016 09:16 PM #21
June 28th, 2016 09:22 PM #22
June 28th, 2016 10:00 PM #23
This is correct.
This, I don't agree.
It seems yes. But as I said, I don't agree.
W (Watts) is a measure of power, not temperature.
A bulb may operate cooler, but that will never mean it draws less current. If wires/fuse for the fog lights are rated *more than* 30W, then OK lang ipalit yung H11 sa H16. But that's highly unlikely.
Siguro safe ang reflector bowls dahil cooler ang operating temp nung bulb, pero sunog ang wires/fuse dyan pag underrated sila.
BTW, please do not put LEDs/HIDs on halogen reflectors.
July 30th, 2016 06:57 PM #24
Sa US pa ako nakabili ng yellow h16 bulbs for my fogs.
Never use an h11 halogen bulb on an h16 foglight assembly. Mas mahaba yung glass part ng h11 bulb. Mas mataas din wattage. It will cause your foglight assembly to run hotter than designed, may cause fogging or worse, melt your reflector and lens.
Also, please don't use LED and HID bulbs on fogs. Sobra lakas ng glare sa kasalubong, sabog ang ilaw. Unless Philips or PIAA led bulbs na maganda yung optics and very similar ang lightsource sa halogen filament.
Kung nakukulangan talaga sa ilaw, get a proper hid retrofit.
- Nov 2005
- 824
July 31st, 2016 09:55 AM #25Since i will be installing leds in my stock h11 projectors, im also planninh to install h16 super yellow on my fogs for rainy days. What is better 2500 or 2400? Nokya has the 19w 2500 while ipf has the 2400. Planning to get mine from amazon and have my relatives in the US carry it back to the country
Sent from my SM-A800I using Tapatalk
July 31st, 2016 10:59 AM #26
- Nov 2005
- 824
July 31st, 2016 11:04 AM #27
July 31st, 2016 11:55 AM #28
July 31st, 2016 03:47 PM #29
Sharing my H11 & H16 Bulbs
Purchased thru Yahoo Shopping Japan
Sent from my iPhone6s using Tapatalk
- Nov 2005
- 824
July 31st, 2016 04:59 PM #30Nice! Did you have it shipped to the Philippines? If so, how long did it took to arrive?
I would also do some research into the final-design-function performance of carbon fiber hoods...
Carbon fiber hood
