Results 11 to 20 of 50
- May 2014
- 52
November 19th, 2014 02:22 PM #11thanks guys, plano ko kasing gumamit ng osram fogbreaker h11 sa fogs, since nag palit na ko ng headlights to nightbreaker, para mas maganda yung combination.
November 20th, 2014 12:03 AM #12
^ Check mo yung haba ng FB. Kung mas mahaba kesa yung stock na H16, magiging sabog yan.
- Apr 2008
- 202
June 22nd, 2016 09:15 PM #13Kung H16 and 19W lang ang stock bulb specs (halogen), ok lang ba palitan ng H11 30W (LED)? Fit naman siya ang concern lang is higher wattage, but LED na
- Aug 2012
- 2,767
June 22nd, 2016 10:04 PM #14See page 1. Somebody already replaced stock H16 19W bulb with H11 51W bulb. Your H11 30W should be no problem. Does not matter if halogen or LED.
Sent from my D5833 using Tapatalk
- Apr 2012
- 3,469
June 22nd, 2016 11:14 PM #15Had a weird problem with my vios regarding this H16 bulb.
Stocks are originally H16. When the time it conks out i ordered H16 to my friend na may auto accessories shop. He told me na H11 ipapalit kasi fit din daw. To cut the story di pumapasok ang H11 we tried it sa binebenta nya na after market na fog light para sa vios pumapasok H11 dun sa bahay ng aftermarket. Pasok na pasok. When we tried to put the H16 from aftermarket to my orm fog light, ayaw pumasok ng bulb kahit H16. I find it weird. Kaya nag bawal ng sides na metal sa H11 para lang pumasok sa akin
Sent from my LG-H818 using Tapatalk
June 23rd, 2016 10:13 AM #16
- Apr 2008
- 202
June 23rd, 2016 03:06 PM #17So if you compare the 19W halogen vs 30W LED, mas higher consumption pa din talaga yung 30W kahit LED pa siya?
Also, tried comparing H16 and H11 side by side, mas mahaba yung H11.. But they both fit exactly
- Aug 2012
- 2,767
June 23rd, 2016 04:27 PM #1819W and 30W are already the power consumption bro. Unless the LED packaging states 30W is equivalent halogen power. In which case, the power consumption will be lower.
- 54,192
June 25th, 2016 08:33 AM #19
June 28th, 2016 08:48 PM #20
H11 and H16 both are the same size but not the same wattage, H11 55w while H16 19w, it is not also advisable to use H11 on a H16 oem because the rating of the stock wire harness may not carry the 55w. Or worst come to worst the h16 projector might melt.
Sent from my iPhone6s using Tapatalk
Not just the engine. It's literally a D-Max with Mazda styling, but everything mechanical is Isuzu....
2022 Mazda BT-50 (3rd Gen)
