Results 1 to 8 of 8
January 18th, 2013 10:51 AM #1
Hi guys, need your help. Last week, the right headlight low beam busted out. High beam still works. Changed the bulb and two days later the left headlight low beam naman yung napundi. Is the bulb or is there a problem with the fuse na? Or fluctuating yung power and could possibly be caused by the battery? Twice napundi pag bukas ng light bulb right after the starting the vehicle.
Any help would be appreciated. Vehicle is Honda Jazz GE 2009. Thanks!
January 18th, 2013 10:58 AM #2
It is neither the fuse or bulb. Maaaring may problema sa electrical system mo sir.
January 18th, 2013 11:15 AM #3
I see. Do you have a good electrical shop in mind where I can have it diagnosed and fixed?
January 18th, 2013 11:59 AM #4
gaano na ba katagal ang HL bulb mo, noong magpalit ka isa lang or sabay mo pinalitan?
Tsikot Member Rank 4
- 2,719
January 18th, 2013 12:11 PM #5observe the new bulbs for the meantime ... if they fail too soon, you really have a problem ... more often on loose bulb sockets
January 18th, 2013 05:17 PM #6
January 18th, 2013 05:18 PM #7
BANNED BANNED BANNED
- May 2012
- 142
January 23rd, 2013 11:04 AM #8sir, kung palaging napupundi ang mga bulbs,please check for loose battery terminals. clean the terminals properly. tapos, lagyan ng grease.
when the battery is loose(even for a couple of seconds), a destructive 18v or more is applied to the bulbs or any other device connected to the the battery line
nawawalan ng regulation ang alternator which causes the voltage to go sky high. hope your problem will be solved by this tip. happy motoring!!
Is it just me or have traffic worsened this week compared to pre-Holy Week? Is it because people...
Traffic!
