Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 55
    #31
    I have scangauge 2. It connects to the obd port and gets power there. It reads out voltage while cranking. Sooo. Obd has power during cranking.
    Maybe elm327 with Torque app can help read it out during crank?
    Mar 2004
    #32
    If your battery is in the trunk or under the seat, there's usually a convenience connector in the engine bay ...
    May 2017
    #33
    i read it before i start the engine, with the key on ACC.
    once the engine starts, the reading is now a reflection of the alternator's performance, and not the battery's.
    i want to read it during the cranking period, but i simply can't read it... probably something to do with my eyes and the gadget's design...
    same observation here
    Dec 2009
    #34
    ^if you want real time voltage reading use an oscilloscope
    Sent from my SM-G532G using Tapatalk
    #35
    When starter cranks, Vdrops as low as 7V that most electronics can't operate on that level including the voltmeter. You may use
    a stand-alone voltmeter for more accurate reading or the appropriate battery tester that could operate from 5V up to 24V.
    #36
    yun luma kong voltmeter bro, kita ko drop ng voltage while cranking (3k battery at 11.9v) .. lowest i read nga lang is 8.xx volt dropped from and nagstart naman yung vios.
    ganito itsura ..
    eto yun last ko .. nag 00.00 volts while cranking ..
    eto plano ko ipalit, sana ganun din PLUS may qc 3.0 charging na ..
    Jan 2009
    #37
    ^Naka rekta ba cig lighter plug mo sa battery?
    Alam ko temporarily nawawala power sa cig lighter pag nasa “Start” ang susian.
    #38
    sa stock cig port lang bro
    #39
    except for the car battery it is supposed to measure, the old electromechanical meter does not need another power source.
    but it is difficult to read, and i am not entirely sure of its accuracy, during that very brief moment...
    Feb 2014
    #40
    there can be tons of voltage drop depending on where you measure the voltage during cranking that's why the batt analyzer is clipped directly to the battery during testing
Does a voltmeter (using the cigarette lighter plug) help us determine the health of the car battery?
