Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
    pwedeng indicator ng batt voltage
    pwedeng burloloy sa loob ng sasakyan
    Apr 2006
    odinary VOM would do the job. Around 350 petot lang ata ung mga china made. All around usage pa. hehehe
    Oct 2005
    Thanks people.
    Ngayon ko lang nalaman na mayroon na pa lang voltmeter na pwede i-plug sa cigarette lighter.
    May 2005
    Quote Originally Posted by lakay
    Tatanungin ko rin sana kung anong gamit niyan, kaya lang nuunahan mo ako.
    Digital voltmeters are instruments that measure voltage or voltage drop in a circuit. They use solid-state components and display values digitally
    Jun 2005
    sir's I'm intersested also, kindly post the shops name and address.
    Quest Audio???
    Thanks
  6. #16
    ang disadvantage ng portable VOM is di mo siya pwede imonitor kung nasa biyahe ka na... unlike yang permanent, anytime ka tumingin, humahataw ka sa highway, o stuck sa traffic, mamomonitor mo talaga kung maganda ang karga ng alternator mo... dapt maintained kasi ung 13.5v-14.5v kahit na full load upang maiwasang madrain ang battery mo...lalo na kung naka av setup ride mo...
    madzie71, accurate po b ung digital volt meter? d po b dapat baba ng 13.5v kht full load?
    Jan 1970
    for proper monitoring, dont you need 2 volt meters? 1 for battery to make sure it can still sustain the 12v, and 1 for the alternator, to make sure that it is delivery enough voltage to charge the battery.
    Oct 2004
    Quote Originally Posted by slip-slick
    since they are connected in parallel, they will always have the same reading (assuming di significant ang losses sa wires ha...)
    nakabili n ako ng volt meter. readng nya 12-13v kpg full load. ok lng b un? d b mababa?
Digital Voltmeter
