Results 1 to 10 of 82
August 9th, 2007 02:47 AM #1
Has anybody tried to install Bosch Europa's?
I just got mine and noticed that the connectors do not indicate polarity for positive and negative.
Are they interchangeable?
August 9th, 2007 01:37 PM #4
may polarity po yan. btw hindi lang tutunog pag nagkabaligtad - no need to worry.
August 10th, 2007 10:13 AM #6
hmmm... yung europa ko parang may + - ah?
anyway tama di nga tutunog yan pag baliktad just make sure meron kang inline fuse at relay
August 10th, 2007 05:34 PM #7
And make sure you mount it on a spot where it won't be exposed to water too much... that horn model is sensitive to getting wet (but i love the sound).
August 10th, 2007 10:48 PM #8
August 11th, 2007 06:18 PM #9
Slightly OT, do you know the frequency of those horns? The one we bought na standard Bosch "pit-pit" have 420Hz and 335Hz for the high and low tones respectively. TIA ;)
August 13th, 2007 11:39 PM #10
Thanks everyone for your inputs.
I started my installation yesterday and did a few tests and here is what I found.
1) The horn's metal parts cannot be grounded.
2) The terminals must be connected to + and - connections and are interchangeable.
mbeige, in answer to your question, the horns frequencies are 300Mhz and 375 Mhz. I have heard of some people fine tuning and adjusting the horns to a higher frequency but haven't yet discovered on how it's done.
Megaforce lasted 4.5 years ... with CTek charger ...
