Results 191 to 200 of 201
September 23rd, 2018 10:44 PM #191
Good pm sirs. Does any of you already replaced the keys for sonic? The buttons of mine got damaged. Also, do you recommend a genuine parts dealer for stabilizer link and brake pads? Thank you
September 23rd, 2018 10:56 PM #192
September 23rd, 2018 11:06 PM #193
September 23rd, 2018 11:11 PM #194
Anytime, sir! You can buy key fob shells off ebay for cheap....
Replacement Remote Key Shell fit for CHEVROLET Sonic Remote Key Case 3 Buttons 73213 918343 | eBay
September 23rd, 2018 11:24 PM #195
- Oct 2018
- 4
- Jul 2019
- 81
August 6th, 2019 01:21 PM #197Sa mga owners, do you recommend this car model? Hindi ba sakit ang ulo looking for parts and the price?
August 6th, 2019 03:25 PM #198
There are 3 units in the work fleet since 2013. Think of the Sonic as an appliance. Engine & suspension have never had problems. Just regular oil changes for maintenance. It's a regular AT, not a CVT.
The lone trouble the units have seen has been the AC Evap Temp Sensor, PN: 95018085. It is a common Chevy fault. Php450 fix. Easy DIY replacement under the dash. For parts & consumables, Thunder Automotive carries em outside casa. Prices are comparable to just about any modern car.
Here are the perceived pluses of the Sonic:
-Low tech, reliable GM Family 0 1.4 NA port injected engine developed by Opel. It comes paired w/ a regular AT & hydraulic steering assist. Generally, easy to maintain.
-This car has the odd combo parents seek as ideal 1st car for the kids. Low on power & high on FC....meaning, it'll keep em safer than the faster 1s & home more than the econo 1s.[emoji16]
-Dreaming a VW Golf? The hatch, from a distance, can be mistaken for 1.....if you're a lil under the influence.[emoji15]
-And, like the Golf in Ph, it has a chance of turning into a rarity...Chevy has decided to drop the Camaro & this model.
-You won't be mistakenly flagged for a cab.
-Sonic here, unlike in the US, uses wheel PCD of 4x100 instead of 5x105. This means more aftermarket wheel options. An offset of et35 will set the wheels nicely flushed.
-The suspension is solid, silent & reliable.....but on the numb side.
-You can grab a used Sonic cheaper than most in its segment. The advantage of low resale![emoji106]
Are you decided on 1 now, sir?[emoji4]
- Jul 2019
- 81
August 7th, 2019 11:07 AM #199Thanks for the long explanation. Not a car guy but I understood most of it. That is true the resale is low. I saw a post on FB and I wanted to check if the model is good (which you have answered). The only thing that affected my thinking about the Chevy is my wife, owned one before and she said it broke down. Anyway, thanks again.
October 16th, 2020 09:30 PM #200
What used to be overnight delivery for LBC took 9days. They've become among the slowest now....shipping sea at air rates.[emoji852]
After that short hibernation, DIY-swapped the leaky coolant expansion tank & cap earlier today....then, bled & monitored to be back in good service order.[emoji4]
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
