Results 141 to 150 of 152
June 6th, 2019 07:07 AM #141
June 7th, 2019 11:04 PM #142
^ Thanks, Sir G_A. Pinalitan ng Thunder, I just presented the receipt. They considered kahit almost 3 weeks na nakalipas. Nakita ko din itong NOTICE na naka-post sa kanila:
July 7th, 2019 01:26 PM #143
Done with all fuids changeout.
Total labor cost = 1,300 pesos with suking shop.
Change engine oil (6Liters), ATF (3 liters), Gear oil (3 liters). All materials from Thunder.
- Feb 2020
- 17
February 18th, 2020 12:27 PM #144Last edited by DreamTracker; February 18th, 2020 at 12:29 PM. Reason: Redundant wording of 'ask'
- Feb 2020
- 17
February 18th, 2020 12:32 PM #145Last edited by DreamTracker; February 18th, 2020 at 12:34 PM. Reason: correction of 'month' spelling 😊
- Oct 2023
- 6
October 24th, 2023 09:37 PM #146Hi! Greetings from Argentina! Nice forum! I have a 2018 Chevrolet Trailblazer 2.8 diesel 4x4 200HP 6 gear AT, made in Brazil. I am very happy with the SUV, economical in fuel consumption (10 liters per 100 km), very comfortable for long trips. It has 56,000 km. I would like to know opinions on two topics about time lapse maintenance: 1- The owner manual advises changing the timing belt at 100,000 kms but nothing about the maximum time in years if that mileage is not reached. I only have 56,000 km and 5 years of use. What does Chevrolet Philippines recommend in these cases?
2-What about changing the automatic transmission oil? It's Dexron VI. The manual here speaks of no change, except for severe use, it recommends changing at 80,000 km (city, short trips, carrying caravans). What exchange system do you recommend? Just open the crankcase and let the old oil flow and refill later (where much of the old oil remains) or with a dialysis machine? I've heard pros and cons for every method....
Thank you
- May 2008
- 137
October 25th, 2023 06:27 PM #147Hi mijoeldotor, I have two handbooks that I can share which if you are interested, you can pm me for your email. The 1st one is for the older body released until 2016 while the other is for the newer body released 2017 onwards which include your vehicle. They have the same engine but shows different maintenance intervals on some parts. For reference, I have a 2014 Trailblazer LT 2.8 Duramax Diesel A/T.
1) Timing belt: For my 2014, it indicates 60,000 km replacement. In the handbooks I have mentioned, the older one says 60,000 km or 6 years. But the newer handbook with the same engine says 240,000 km (100,000 km for severe). Note that the handbooks I have mentioned were just downloaded from the web but these should be the same since they are specific for the Gen 2 Trailblazer with same engines.
2) Automatic Transmission Fluid: Both handbooks indicate that it doesn't need replacement.
Sent from my Xcover Pro using Tsikot Forums mobile app
- Oct 2023
- 6
October 27th, 2023 10:51 AM #148Hi blacksilver323! Thank you for the answer. In South America we have 3 models, as you said the first one until 2016, the 2017 facelift, and the 2021 facelift 2. For timing belt, the owner manual (handbook) of the first generation recommend replacement at 160.000kms, the second gen at 100.000 (my model) and the newest at 240.000 (100.000 kms for severe) I do not know why so different, because the engine is the same as you said! I'm glad to see GM recommend there up to 6 years. No time lapse mention here, that was the problem, because there is no formal opinion from GM on this, so each mechanic or dealer has a different opinion. The GM timing belt part is 24591047.
I've read at in other forum a user had the timing belt cut at 135,000 km and 7 years old, bending valves.
I guess the automatic transmission fluid must be replace. Have you replaced it?
- May 2008
- 137
October 27th, 2023 12:47 PM #149Yes, I have changed the transmission fluid at 100K km but outside dealership already. I have read for Holden Colorado, the equivalent in Australia, the recommended is at 150K km (or 75K for severe usage).
- May 2008
- 137
October 27th, 2023 09:28 PM #150Hi mijoeldotor, I double checked my user's manual for my 2014 Trailblazer 4X2 AT, the following are the recommendations. The previous I have mentioned above are my cross reference from other countries' handbooks for the same car variant since I think the recommendation of our dealerships here as also indicated in our user's manual are too early. Nevertheless, please refer to below:
1) Timing belt: 60,000 km or 3 years
2) Automatic transmission fluid: 80,000 km or 4 years (40,000 km for severe operations)
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
