Page 1 of 2 12 LastLast
Results 1 to 10 of 152
    the photo depicts how bad the 2 rubbing parts when the shock absorber bushing is gone.
    Feb 2017
    Metal eats metal mate, ain't nothing gonna save them from doing so.
    Every once and a while on a Highway, turn off your radio and listen carefully, sharp turns and listen, bumps and listen, straight line and leave the steering wheel (Responsibly) and observe man, you will be able to spot all these problems early in case they arise.
    Under chassis inspection is always a must if you have the place and equipment, but not everyone is fortunate enough for that. I do it when cleaning the under chassis in a gasoline station, the vehicle is left high and for those you can't spot you can ask the guys to observe for you. Also when doing your wheel alignment.
    Your best bet in that case is an under-chassis shop inspection, P400 or so, they will left the car and let you know if there is any, will be a good chance to check it yourself as well. 3 and 9 o'clock as well as 12 and 6 o'clock for all your wheels will also make you check your wheel bearings and tie roads. Not always the case though since in rare situations they won't wiggle when pushed but they will emit a harsh sound when you roll the wheels freely, you will be able hear them.
    Don't rebuild these stuff mate, they are gone and your safety is first. Thanks God big time bro.
    Apr 2015
    Hello all,
    Can somebody confirm that these parts are correct.
    Trailblazer Chevrolet 2015 LTZ SE.
    Thanks a lot.
    Pulley Idler. GM# 94722018
    12605492
    Pulley Timing Belt Idler GM# 12581701
    Bearing Tensioner GM# 12625560
    Belt Timing GM# 12625215
    Drive belt 6PK2871 (Gates Micto-V K061130) 13/16" x 113 5/8" OC
    Tensioner Auto GM# 24585348
    Water pump GM# 12645126
    Feb 2017
    Quote Originally Posted by kiwileader88 View Post
    Hello all,
    Thanks a lot.
    12605492
    Check with Thunder Banawe mate or the CASA to be perfectly sure about it.
    I have only the timing belt and drive belt for now.
    Timing Belt: GM#24581173
    Drive Belt: GM#12642668
    Apr 2015
    Quote Originally Posted by shadyanderson09 View Post
    Thanks for sharing, BTW the correct details below
    Drive Belt: GM#24581173
    Timing Belt:GM#12642668
    Anybody know the part number for the REAR brake pads?
    Thank you.
    Thank you.
    IIRC, the make that i used to replace my oem brake pads is bendix.
    just brought the sample to my suking auto shop when i bought it.
    Feb 2017
    Thank you.
    Lol Sorry dude reversed the info, was kinda clumsy when I have pasted the part numbers.
    Not really sure, never changed them but fat as day one. Check the pads first, if your complain is the sponginess of the brake then it's normal in the TB. Lots of manufacturers aim for this design, yeah it's not a defect or something, due to wrong chair adjustment by inexperienced drivers especially with long legs, a slight hit in the brake pedal won't cause you to get rear ended. It's not that far though, but it won't bite with a simple touch.
    Apr 2015
    Hello,
    Thank you for the info shadyanderson09.
    Here are the part numbers that I have with all shared from this forum.
    Please let me know if I missed something.
    Thank you all.
    2000kg kerb w [emoji848]
    Feb 2017
    StockEngine. It's amazing mate that it took all these poundings with more than half of it's core is gone. Glad He was able to bust it early, one more reason to inspect under-chassis regularly.
Chevrolet Trailblazer Maintenance...
