Results 1 to 9 of 9
June 25th, 2010 05:41 PM #1
paano i-adjust ang sensitivity ng alarm. nag aalarm lng kasi pag hinampas ng malakas at kapag may dumadaan na kotse or motor bike na maingay ang muffler.
- Jan 2008
- 4,726
June 25th, 2010 08:05 PM #4may car alarms with separate vibration sensor which has a potentiometer to adjust its sensitivity..
some car alarms need to adjust by inserting the car key and position the ignition to ON then press the valet switch (depends on the car alarm type which you need to long press or press 3 times) then you will hear chirps. sensitivity can be adjusted on your remote
June 26th, 2010 01:00 PM #6
I have the same problem. I bought a 2nd hand 2004 Honda City. The manual for the alarm has been lost and I don't know where the box/ system to adjust the sensitivity is located. I tried looking under the steering wheel but I can't find it. The owner left for abroad already and I don't have any contact with him. The brand of the alarm system is CODE ALARM, and manufactured in 2002. Help please. Thanks.
June 26th, 2010 01:15 PM #7
- Jun 2010
- 8
June 29th, 2010 11:49 PM #9mga sir gud day po, ang brand po ng alarm ko ay carrera, nabili ko po ung auto ko included na ung alarm, ung pinaka remote nya may red button na may nakadrawing na bawal ang baril, para saan po ba ung button na yun? paano po ba cya gagana? thanks a lot po.
I would also do some research into the final-design-function performance of carbon fiber hoods...
Carbon fiber hood
