Page 53 of 351 FirstFirst ... 34349505152535455565763103153 ... LastLast
Results 521 to 530 of 3510
    Sep 2014
    #521
    Quote Originally Posted by epsi View Post
    check the firmware version, real SJ4000 New Firmware uses 20140324V02
    also this can help para malaman ang fake vs real
    https://dl.dropboxusercontent.com/u/...l_and_fake.jpg
    Thanks for sharing.
    Oct 2014
    #522
    Quote Originally Posted by yellowboxph View Post
    Make sure you get the authentic one. May mga fake din na SJ4000. Officemate ko nag-order sa L*z*d* and turned out it was fake. Video quality was bad.
    Got mine through Lazada. Mukhang di naman fake and it uses novatek chipset.
    Dalawa kasi yung sa Lazada - one with that Novatek chipset sa caption at isa na wala (much cheaper).
    Got the P4,720 less P500 voucher/discount
    Oct 2014
    #523
    1. Yes you can. The SJCAM's cable is just like that of Android phones.
    2. About 45 min of continuous recording on battery power.
    3. I suggest getting a high quality car charger (I use a Capdase USB charger), but if you wanna cut costs, yes a CDR King USB charger will do.
    I would also suggest getting a really long cable so you can have the cable routed up your headliner and A-pillar so it doesn't look messy.
    Where in particular can I find that cable which is long enough to install in such a way? Been at SM San Lazaro at naikot ko lahat ng shops don wala ako makitang cable na ganun kahaba.
    Oct 2014
    #524
    Kanina pinara ako from Monumento Circle, mali daw pasok ko sabi ni mr. kotongero.
    Pag baba ko ng bintana, ask ko agad anong violation ko at nagmamadali ako at kunwaring iaabot lisensya (kahit di nya hinihingi). Sabi ko di ako makikipagtalo at tiketan na ako kung titiketan (dahil nagmamadali nga ako) pero sabi ko siguraduhin nya na tama ang violation (kung mayron man) na isusulat nya sa tiket dahil sabi ko may dashcam ako, sabay pihit paharap sa kanya. Ayun, pinaalis na lang ako ni mr. kotongero kesyo daw kasi nakakaabala na sa traffic.
    Oct 2014
    #525
    I believe I got one with the NOVATEK Chipset =)
    Feb 2007
    #526
    ^you can check on the cam settings itself.
    Oct 2014
    #527
    how can i check is its original?
    #528
    Here's mine, mahirap na magtipid sa mga ganitong bagay. it can be your life and death *knock on wood* or
    for insurance purposes
    Bought mine for 3,600.
    Ito sample video ng day and night.
    Galing na ako sa mga 1500,2000 and above. ung gabi niya literal gabi walang makita.
    #529
    San nabibili yang sj4000? Sa old lang wala sa mga mall?
    May 2007
    #530
    Quote Originally Posted by xvanquish View Post
    4,750 plus 450 ung suction mount. may kasama 16GB na micro sd. sure orig cya and reputable ung shop. sample video below:
    *xvanquish, musta naman po ang kapit ng suction mount sa windshield hindi ba nahuhulog or bumibitaw pag nabilad sa araw ang sasakyan? TIA
Blackbox DVR/Dashcam
