Page 10 of 11 FirstFirst ... 67891011 LastLast
Results 91 to 100 of 109
    Mar 2016
    #91
    Quote Originally Posted by lexter25 View Post
    hindi po sila parehas ng antenna. kulay blue yung connector ng gen 2 tapos gold naman sa gen 1
    mga sirs yon toyota avanza G 2016 HU ano po kulay ng connector ng antenna, gold or blue po ba? salamat
    Sep 2018
    #92
    Quote Originally Posted by Louie Anson Ng View Post
    sent you a pm sir.
    Pa PM no. Louie Anson Please
    Sep 2018
    #93
    Quote Originally Posted by brymed View Post
    Anyone interested for SD cards with GPS software navigation for car winCE navi ready head units? Please search through lazada "gps software". SD cards available Igo 8 2016 q3 & 2017 Q4 phil maps and igo primo q4 2017 phil map with 3d buildings and landmarks 2017 data for major cities of philippines. Thank you.
    ok kaya yan sa suzuki ertiga 2017
    Jan 2019
    #94
    Sir my gps navigator application kayo para sa Chevrolet TrailBlaizer napaglaruan kc ng bata nawala ung micro SD...
    Mar 2018
    #95
    Quote Originally Posted by johtrikimica View Post
    Suzuki Ertiga uses iNav.
    Jan 2019
    #96
    Quote Originally Posted by SUREFIRE77 View Post
    Anyone knows the number of Louie Anson? Need one SD card for my montero..tnx
    Good pm..po..new po ako dito..may nabili din akong Montero sports 2014 GLX model...wala din yun sd card ng navigation.. meron po ba dito makuhanan...please tex me po 0906-3302445...Anna..
    Feb 2019
    #97
    Quote Originally Posted by kempee1989 View Post
    boss pa pm nmn po ng copy ng para sa wigo.
    09356210525
    Sir baka pwede rin ako makahingi ng copy para sa Montero 2014 tia
    May 2019
    #98
    Quote Originally Posted by ramrac View Post
    Merin ako Papago X8 with multiple baud rate. Tested to work in most in car navigation HU. Pm me if u like a copy
    Sent you a pm.
    Jun 2019
    #99
    Quote Originally Posted by G1NA View Post
    Sent you a pm.
    Sir / Madam, pwede pa share Papago X8 with multiple baud rate for car navigation na corrupt kasi sa akin ayaw na gumana.
    Thanks.
    Apr 2010
    #100
    Since may existing thread na, dito ko na lang i-post. Baka matabunan nga lang
    My Toyota stock head unit's GPS maps is not being updated anymore and I really don't like its interface.
    Admittedly, I don't use the head unit's GPS as I prefer Waze, but I have free time, and I like free & opensource software... (the GPS software isn't opensource, but the maps are)
    This guide is designed for head units with Windows CE OS. It should work with the first generations of the Innova, Hilux, and Fortuner. I believe the Wigo has the same head unit. You may need to disassemble your front panel and physically inspect the head unit for stickers that it has Windows CE, mine has one the says "Windows CE Embedded 6.0"
    1. Remove the SD card from the head unit, insert it into your PC, and backup all of its contents
    2. Reformat the SD card
    3. Analyze the folder hiearchy of the SD card's backup. There should be a folder named "Navigation". Under it is "Navigation.exe". This is the one initiated by the "Navi" button on your head unit. This may vary on other head units.
    4. Create a folder named "Navigation" on your SD card.
    5. Download mapFactor for Windows and install: Navigator Free | mapFactor, s.r.o.
    6. Click the "Use Free Key" button
    7. Click "Install Application, then click "Install Pocket Navigator"
    8. Click "Windows CE device". Click "Install to a memory card"
    9. Navigate to your SD card > Navigation. Click Next. It will copy all mapFactor files into the SD card. When done, click OK
    10. The program will prompt that you need to install map data, click Yes
    11. Click "Install Map Data", then click "Install maps to a memory card"
    12. Navigate to the SD card > Navigation. Click Next.
    13. Click the "Free regions" tab, then check "Philippines OSM" under "Asia". Click Next
    14. Check "English (US)" under "Voice languages". Click Next. It will download what maps and languages you have selected. When done, click OK
    15. Navigate to your SD card's folder > Navigation. Create a copy of "navigator.exe" and name it "Navigation.exe". You can do this with other head units, you can see where this is going...
    16. Remove the SD card and insert it into your vehicle's head unit.
    17. Configure the software on your head unit via the Menu > Settings button
    I just zoomed out as I don't really want to reveal my location, but streets are visible
Installing GPS software/maps in an SD Card
