Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Sep 2005
    5-10 minutes to fix on a satellite signal is agonizingly too long. Current receivers like the MTK chipset takes less than a minute for the first fix.
    GPS on the PSP discussed here:
    http://tsikot.yehey.com/forums/showt...t=24232&page=4
    Sep 2008
    Up ko lang po ito, meron na po nabibili GPS para sa PSP, parang yung camera siya sa PSP, tignan nyo nalang po ito
    http://www.engadget.com/2006/12/07/g...-goes-on-sale/
    2006 pa po yan
    Sep 2005
    Gaya nito?
    Software is Go!Explore with UK and NI maps ... unfortunately there's no map for the Philippines.
    Jan 2009
    Currently, only Garmin GPSes are supported by the Philippine map available at Roadguide.ph and OSMPhil, aside from AVT Navigators which uses Accu-Map (proprietary).
    If you intend to use it in the Philippines, invest only on GPS products made by Garmin or on GPS hardware that can run the Garmin Mobile XT software (ie. some Windows Mobile and PalmOS smartphones, etc.)
    Sep 2005
    There's a member here that uses his PSP as a satnav in the Philippines. The software is MapThis, which is free to download. The local maps are from www.openstreetmaps.org, and Google maps work with it, too.
    I'm just not sure if the current version of MapThis already has turn-by-turn voice prompts. But it does support different serial GPS receivers like the Holux GPSlim ... unlike GO!Explore which only supports the PSP290.
    Jan 2009
    ^ I suppose you can go that route (no pun intended). It indeed does look good as a novelty item and it seems promising. But if you need a robust solution that'll pretty much cost the same as a PSP+External GPS, a standalone Garmin GPS is your best bet. No more hacking and forcing things to work. The map is updated almost on a monthly basis (roadguide), adding more roads, POIs and incorporating other refinements. You power it up and it works right away.
    Sep 2005
    I believe the question was how to put a Philippine map and GPS on his PSP ... so MapThis may be his only route now. And you can't really argue the cost of a Garmin PNA when he already has a PSP. But if he doesn't, I would recommend a Garmin myself, but only because of the roadguide.ph map and nothing else.
    Jan 2009
    ^ True.
    Dec 2007
    Quote Originally Posted by Ryoichi View Post
    Hello po sa inyong lahat!!
    Ahh medyo may interest po ako sa mga Cars at sa GPS kaya gusto ko po sanang lagyan yung PSP ko ng Map.
    Ahh nabasa ko po dito sa inyong site na pwede pong lagyan ng GPS or Maps ang PSP...
    Ang tanong ko lang po ay kung papaano at saan po makakakuha ng maps para po sa Philippines...
    Maraming salamat po sa inyo!!
    You will need to have a custom firmware installed on your PSP which I supposed you already have. Download MapThis! http://dl.qj.net/MapThis-v0.5.20-PSP...5200/catid/151
    Save it to your /PSP/Game folder
    To download Philippines maps you'll need the Global Map Download Tool or GMDL. http://www.in7ane.com/psp/gmdl.html
    Install it on your PC (.net framework should already be installed). You also need an internet connection because it downloads the map via google map or openstreetmap among others. Save the files that will be created by GMDL and save it inside the maps folder of mapthis.
    For a more detailed steps visit http://www.dcemu.co.uk/vbulletin/showthread.php?t=60230
    Mar 2007
    To all,
    Somewhat eying this gizmo, although buying will have to be done online.
    Can any PSP-GPS'ers provide feedback? Does it function as its expected to be? More than a year has passed and the maps may have updated/improved since then.
Help po tungkol sa  GPS para sa PSP
