Results 531 to 540 of 758
November 16th, 2009 11:18 PM #532
Hello, prince777. Sorry for the very late reply. I wasn't able to check the forums for several months because of problems at work. I still have problems ... but a bit more time to goof around.
First, a bit of explanation. If you buy Garmin Mobile XT (which is on an SD card and comes with a detailed map), the product key is on the SD card. It will work with any GPS receiver that can connect to your device.
If you use the downloadable version of Garmin Mobile XT (from the Garmin website), it only comes with a worldwide base map (major roads only). Here's where the roadguide.ph map comes into play ... because it's free and doesn't need a product number to use. The (small) problem is, that version of GMXT will only work with Garmin GPS receivers. The solution is to use a crack so GMXT can "see" the non-Garmin receiver.
Google for the jetmouse keygen (at least v1.3). It basically puts your device's unique ID number as a text file which you have to put into the /Garmin folder. HTHLast edited by StraightSix; November 16th, 2009 at 11:21 PM.
November 16th, 2009 11:47 PM #533
Wala nga talaga ... the iPhone 2G doesn't have a built-in GPS receiver. The iPhone 3G and 3GS do.
With the release of OS version 3.0 mid-year, Apple had removed its restrictions that prevented the earlier iPhone OS from having a full and proper navigation application. Kaya nagsulputan bigla mga iPhone version ng iGO, CoPilot, etc. ... though I haven't seen a Garmin version yet.
Here's my 3G with Tomtom. It now does its job as a backup satnav very well.
- Dec 2009
- 1
December 23rd, 2009 01:22 AM #534
January 12th, 2010 10:07 AM #535
Whenever I use mine, I mount it so it would just be above the center of the dashboard (just above the radio) from my point of view.
But this position will still take my eyes away from the road.
To minimize that, I use the voice function of the GPS where it will say the directions to the destination. I just look at the GPS when I am at a stoplight or other safe moments.
January 12th, 2010 10:37 AM #536
I keep it to the right of the rearview mirror, on the passenger side and facing me.
1. It's within my arm's reach
2. It doesn't block my view
2. It's behind the darkened area of the windshield (above the AS-1 line), practically hidden from prying eyes outside
3. Allows me to hide the cable inside the narrow channel between the windshield and the headliner
4. The text-to-speech feature keeps my eyes on the road
January 12th, 2010 12:58 PM #537
I tried emulating this, but I prefer placing it just above the dashboard, stuck to the windshield. I don't mind having to reach out when saving locations or whenever I need to input anything, and it doesn't really obstruct my view, plus having it near my point of view center line allows me to look at it more safely (compared to having it near the mirror) from time to time.
As to hiding it from prying eyes outside, it's not an issue -- I always remove the mount before leaving the car in public places anyway and I carry the unit with me (I don't leave any valuables inside vehicles anymore -- burned too many times by bukas-kotse gangs). Helps to avoid getting marks on the tint, too.
:now:
[SIZE=1]3611[/SIZE]
January 12th, 2010 08:16 PM #538
i mount mine above the center of the dashboard... i have also observed that the Nuvi somewhat obtains a high degree of accuracy when placed in the center.
January 14th, 2010 05:13 PM #540
Di ko alam about sa miata. But I was able to help my uncle acquire a unit para sa pinsan ko kasi...
6th Gen Mazda MX-5 Miata
