Page 6 of 16 FirstFirst ... 2345678910 ... LastLast
Results 51 to 60 of 152
    #51
    it explains why every other led convert i meet at night, causes me to squint.
    folks who are considering led bulb conversion, should watch this.
    #52
    Good buddy, saan ba meron reputable store ng auto LED bulbs satin?
    TIA :0
    The most popular LED bulb shops here are Keon Sondra and LED Lights PH. I personally use LED Lights PH. Sadly, both of them do produce glare to oncoming traffic.
    Id really like to try the bulbs from Diode Dynamics that i watched from Headlight Revolution a few days ago. From their tests on youtube hindi nakakasilaw.
    Mar 2018
    #53
    Thanks man.
    I guess LED bulbs won't be a welcoming idea for an upgrade unless you find the appropriate type so you won't cause inconvenience to oncoming motorists really.
    #54
    You are welcome. I intentionally adjusted my headlights to point lower para hindi ako makasilaw.
    I see a lot of good projector retrofit places now that are more affordable. Will probably try them next year. Sulitin ko muna itong LED Bulbs ko.
    Mar 2016
    #55
    I'm planning to use yellow LED sa fog light. May nakita ko online na 12k Lumens. Okay lang ba since pointed downwards naman?
    Feb 2014
    #56
    i got 2 pairs of these. H4. i'm also planning to get H11 for the fogs
    multi-sided don't work because they don't match the filament location of the original bulb. but this Nighteye attempts to replicate the original filament by using strings of LEDs. and the LEDs aren't the domed type (referred to in the industry as "HI"). i.e. there's no magnifying lens over each LED so each LED behaves like a point source (lenses enlarge the apparent size of the LED). this better approximates the original filament
    Mar 2018
    #57
    Quote Originally Posted by Vodka View Post
    Is this brighter than a stock Halogen?
    Where is this available?
    Dec 2013
    #58
    Quote Originally Posted by red_one View Post
    I settled with Philips ZES LED because I like the design of the bulb housing. At 8000 lumens, it is already brighter than my HID. My Osram CBI Xenarc D2S HID set is rated 6400 lumens.
    Sent from my ASUS_Z010D using Tapatalk
    Hi bro. Kamusta output ng Philips ZEA lED from D3tech? Maliwanag ba from stock halogen? Planning to use it on 2016 Forty. Clear naman tint ng windshield ko. Pero nahinaan pa rin ako sa stock halogen.
    Oct 2018
    #59
    Where can i find a good supplier for headlights and fog lights?
    Oct 2018
    #60
    Quote Originally Posted by confused shoes View Post
    ^Instead of upgrading to 90/100w, you can try Philips X-treme Vision Plus or Osram Night Breaker Laser. Both are advertised as +130% more lights and both are perfect replacement 55/60w. Di mo kelangan magrelay/harness upgrade/ceramic socket.
    Sir pwede po yan sa 2013 toyota fortuner?thank you..
Good bright headlight to replace the stock headlight?
