Results 21 to 30 of 184
June 1st, 2017 08:36 PM #21
Exactly. Those engines WILL STILL RUN. Yes, sure they will. But at the expense of premature wear of fuel injection mechanicals. Sulfur adds lubricity to diesel fuels of yore. Lower the sulfur, and those mechanical injection diesel engines will just grind themselves to death.
Kawawa si Manong Operator kaka-pa overhaul ng injection pump nya.
June 2nd, 2017 12:04 PM #22
^all mechanical components wear down thats why cars depreciate in value
Youll be surprised surplus engines are more resilient than you claim with the sulfur content ekek thing
Sent from my GT-P3110 using Tsikot Forums mobile app
- Jun 2005
- 3,774
June 2nd, 2017 03:54 PM #24Parang nung time na fully implemented ang unleaded gas sa pinas (mid 90s)
A number of old cars conked out. Ours included due to premature valve damage. Wala na lead that lubricates the valves.
Had to have the engines overhauled and replace with hardened valves.
Ganun din effect ng pagbaba ng sulfur sa diesel engines. Yung injection pump nga lang affected ng added friction and heat.
June 2nd, 2017 07:03 PM #25
Likewise
Better fuel nga eh, produced by the best scientific mind tapos less lubricant pa ang logic
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; June 2nd, 2017 at 07:42 PM.
- Jul 2017
- 13
July 18th, 2017 12:35 AM #26anybody using Total fuels here? Any feedback? parang puro Unioil at Seaoil lang may feedbacks sa users. pero parang walang Total? Mukhang mas maganda ang fuel ng Total since it is a big company in France.
July 18th, 2017 01:00 AM #27
like any gas or diesel, they all have a base and additives. they all work naman..
- Jul 2017
- 13
July 18th, 2017 11:41 AM #28
July 18th, 2017 01:24 PM #29
Despite being a global multinational and the 5th largest in the world, Total doesn't have as much a presence in the Philippines with just a few stations hence the low marketing spending.
That said, they're still bigger than Unioil which has less than 50 stations nationwide. Unioil did a really good job being the first to market Euro 4 fuels, but now it's a level playing field.
On your question regarding the quality of their fuels, they're good enough to serve as the base fuel for Caltex and Shell in some areas in Luzon. The additives are also as good as other multinationals (Shell, Caltex, and Total are the only global multinational fuel brands in the country).
Bottomline - go ahead and try Total.
July 18th, 2017 06:26 PM #30
It is said that although the sulfur content was reduced, lubricity was restored through other means by way of a lubricity additive.... Infineum and Lubrizol comes to mind.
Sulfur in exhaust gasses 'poisons' catalytic converters and DPF. Your vehicle's emissions systems will last far longer within spec (ie. maintains efficiency in cleaning up emissions for the life of the vehicle) when sulfur in exhaust gasses are reduced. If sulfur starts bonding to the cat or DPF, these emission devices would start to fail and stop working.Last edited by oj88; July 18th, 2017 at 06:29 PM.
Is the eMax 7 battery (Pure EV) a newer blade battery than sealion 6? I know one is hybrid and the...
BYD Sealion 6 DM-i
