Results 1 to 10 of 25
January 24th, 2008 12:34 PM #1
Help, newbie here and a new car owner, a Toyota Corolla Altis 1.6S MT. I hired a driver who filled up the car with Petron XCS full, then my permanent driver said that it's supposed to be filled with unleaded only. I called Toyota and asked, was told that we need to drain it and replace with unleaded for it might cause problems in its catalytic converter which is not covered by warranty. Now this is like 30 liters of gasoline! Will it really hurt the engine or I can just use it then fill it up with unleaded next? Please help, and fast.
January 24th, 2008 12:39 PM #2
unleaded naman po lahat nang gas dito sa atin.. wala na pong nagbebenta nang leaded gas... Yang Petron XCS eh 95 RON, I don't think you need to drain your gas tank.
January 24th, 2008 12:43 PM #3
xcs 95 octane, mas malakas hatak ng makina- 44.50 pesos per liter
xtra unleaded 93 octane, mahina konti hatak - 42.70 pesos per liter
the altis can handle both fuels. my sister uses xtra unleaded so far so good no problem with her altis
January 24th, 2008 01:34 PM #4
I'm confused, this Petron ad doesn't say it's unleaded. I'm just worried it's going to cost me more if I keep it running with what's left of the Petron XCS in the tank (was told it's worth a week of city driving) and might immediately cause problems with the part not covered by warranty.
[SIZE=1]The New PETRON XCS COMPLETE COMBUSTION SYSTEM[/SIZE][SIZE=1] gives you more muscle on the road by providing the following performance benefits:[/SIZE][SIZE=1]. [/SIZE][SIZE=1]- Excellent detergency cleans up engine deposits quickly and maintains
engine cleanliness;
- A complex combination of additive chemistries promotes better fuel
consumption;[/SIZE][SIZE=1]
- Better combustion enables the engine to work at maximum power;
- Hydrocarbon emission is reduced by up to 45%.
A 95-RON fuel, new Petron XCS meets the top-tier standards of the World Wide Fuel Charter and octane rating requirements of most modern vehicles. It resists engine knock, provides smoother acceleration and ensures better driveability.[/SIZE]
- Jul 2007
- 16
January 24th, 2008 01:48 PM #5Ganito po yan:
99% of gasoline being sold today is already UNLEADED. Yun nga lang nagkakaiba sa Octane Rating, Additives or yung mga bago ngayon with ethanol.
If your car manual/car dealer recommends 93 Octane fuel rating only then dun ka may problema (Mazda 3 dapat daw 93 Octane lang).
So if the altis can handle 95 Octane you have no problems. Better call your dealer and ask kung pwede ang 95 Octane rating for your car.
January 24th, 2008 02:18 PM #6
Ang tanga naman ng Toyota dealer (?) na yan. Gas stations have long been prohibited from selling fuel with lead as additive for several years now. Engot din nung permanent driver mo, IMO, he should be fired.
Re: the Mazda3 requiring 93 Octane fuel only, that's a bit weird. I don't think Mazda would want to sell a car with an engine like that. I've never seen that warning in any of their advertisements, so I doubt if it's true. May mga managers kami dito with Mazda3 cars, wala naman silang sinasabi sa amin na ganun. Normally, the higher the octane, the better for the engine.
January 24th, 2008 02:20 PM #7
January 24th, 2008 02:23 PM #8
Baka minimum RON of 93 siguro. Mali lang interpretation. Coz it limits you to gas stations that only have this fuel kung ganon.
January 24th, 2008 02:26 PM #9
Sa mga provinces na lang available ang mga leaded fuel. Pero bihira na lang. Ang label yata is "regular".
Sa pagkakaalam ko, ang mga EFI engines can handle from a certain min. RON fuel. The engine is intelligent enough to adjust the timing.
January 24th, 2008 02:28 PM #10
kung 93 RON ang specified, they specify the minimum requirement, so using a higher RON than the minimum required should pose no problem (except that it would cost you more).
If purely for City driving then get the Emax7. since you already have other cars for longer drives....
BYD Sealion 6 DM-i
