Results 11 to 20 of 30
February 18th, 2017 10:56 PM #11
*jut, so where do you gas up, and how will you know if a certain gas station has "clean fuel"?
February 18th, 2017 11:14 PM #12
February 18th, 2017 11:22 PM #13
Most if not all company-owned stations in Manila have clean (i.e. not adulterated fuel). In the provinces, I generally have an idea which stations dump (get from other sources), so I just avoid those. I also don't fill up with generics, because even if they're supplied by Petron or Shell, they have poor operational standards so they might not even be checking for water intrusion in their UGTs.
I fill up where it's cheap (Fairview, EDSA Boni, Mariveles, etc).
February 19th, 2017 12:25 PM #14
February 19th, 2017 01:39 PM #15
- Dec 2007
- 132
February 19th, 2017 08:42 PM #16I owned an accent crdi which require min. 51cetane. I searched their contact number through Internet browser. These are their replies. For Shell I am expecting to have the highest cetane, but their answer is only 50 for both fuel save and v power diesel. So I never gas up from Shell for my accent. For Unioil, their fuel seems to be clear and clean and less foamy, I called up and email but no reply. It would be nice if govt requires them to display their cetane number or those gas companies voluntarily display their cetane number, so that we know what we are buying. For Shell , I will be glad if someone can call up again and verify. Thanks
February 19th, 2017 08:47 PM #17
I don't need to call their hotlines because I'm from the petroleum industry. And like I said, pare-pareho lang yan.
Shell gets 80% of their Metro Manila volume from Total's Manila Terminal. The remaining 20% is split between Shell's Tabangao refinery in Batangas and PTT's depot in Clark.
Part of Total's fuel is imported from Singapore, part from Petron's Limay refinery.
Shell only claims 50 cetane because that's the minimum required by the DOE. But I do random audits of the COQs (Certificates of Quality) of each batch of fuel loaded from the depots' tanks, and most of the time the cetane range is 51-53, sometimes going as high as 55.
Oh, and my girlfriend's dad has been gassing up exclusively with Shell for the past 4 years with his Accent. No problems whatsoever.
Sent from my SM-N9208 using TapatalkLast edited by jut703; February 19th, 2017 at 08:55 PM.
- Feb 2003
- 1,038
February 19th, 2017 10:24 PM #19*Jut703 So if that's the case that only 20% of Manila Supply is supplied by Tabangao Refinery...Where does the bulk of Crude products goes? Shell has a newly built Mindanao Depot, and I believe it is an import finish product from Bukom Refinery...
February 19th, 2017 10:25 PM #20
Isuzu pala makina, at least madali hanapan ng parts.
2022 Mazda BT-50 (3rd Gen)
