Results 21 to 30 of 81
December 12th, 2010 02:00 AM #21
masters, tanong lang po...since wala na sa market ang shell v power at yung may mga e10 eh pangit ang FC, hindi kaya makasira sa old cars / engines say rev-o 01 model ang petron 100? kasi pati ECS may e10 din. sa observation ko sa v-power lang tumaas ang FC ng rev o ko any other 93+ rating ay almost the same...thanks
December 13th, 2010 11:05 AM #22
sir, topic namin ngayon sa HCP is yung cold start problem namin. after a week using this new Blaze, pansin ko nga is yung hard start or tipong palyado pagcold ang engine. now, balik ako sa XCS to check. Indeed, nawala yung "palyado" effect. Sa ngayon, observe ko pa ulit. if ever, mamimili ako.. hard start o better FC.
W/ your Revo sir, pede mo rin i-check muna. wag muna full tank. ;)
- Jun 2011
- 95
July 13th, 2011 11:38 PM #23buhayin ko lang tong thread na to kasi ito lang na google ko eh. hehehe.
Well, comparing XCS,GOLD and Premium.
Premium = 93+
XCS = 95
GOLD = 95
So mas malakas malamang ang hatak ng XCS and GOLD.
ramdam ko to pag nag papakarga ako ng premium, medyo mahina hatak. Then pag karga XCS or Gold malakas hatak lalo na when going up hill. Para sakin parehas lng halos XCS at GOLD though i can vouch na ang pinaka ok for me is XCS, both sa hatak at engine stability.
At dahil you need less gas to accelerate (dahil mas malakas hatak XCS), gaganda fuel comsumption niyo mga tsikoteers!
Kasi subukan niyo shell unleaded, kahit anong diin mo sa GAS mo ayaw umandar, hehehe. ayun lang. ;)
At never ko tinry yung V-Power or Blaze kasi i dont think mababawi mo ng farther distance travelled by the increase in price.
- Aug 2011
- 7
August 22nd, 2011 11:13 PM #24Guys,kapag ba unleaded gasoline ang nakalagay sa manual [mazda e2000 powervan] e di ako pede mag refill ng xcs un 95 octane? Thanks po sa mag rereply!
August 23rd, 2011 04:06 PM #25
- Aug 2011
- 7
August 23rd, 2011 05:13 PM #26*redeemed & to all
Sir,kasi po naguguluhan po ako,me nabasa ako sa iba na masisira daw un engine,topic ito ha sa u.s.,e nasa pilipinas tyo im not sure kung applicable din sa atin,so kung pareparehas din pala unleaded e ok lang din pala un xcs na regular? try ko sana kc un fc ko ang taas sa unleaded e,naalala ko un nissan nuon 5km/ltr nun nun nag xcs ako aroung 6-7km/ltr na,e dito sa mazda kc nakalagay sa manual e premium unleaded at sa tangke ganun din nakalagay,un mga iba nababasa ko totoo tumaas ang km/ltr nila nun nag xcs regular,un lang di nila nababangit kung unleaded ang required ng makina nila,btw carburador po ito di po fuel injected sir.
Thanks in advance po sa mga rereply.
August 24th, 2011 02:14 PM #27
same sa experienced ko sir, mas ok km/L ko using XCS. i can do 8-10km/L sa Civic VTi '97 matic ko, city driving. same din, may "unleaded" na nakalagay sa gas tank cover ko. mas ok nga XCS kasi may cleaning additive..
ito, quoting from Petron's site:
Petron XCS Plus Valvemaster is the unleaded gasoline that unleashes true engine power and provides the following performance benefits:
· Enhanced cleaning action that maintains the same combusting power as leaded gasoline
· Promotes better burning and reduced emissions
· Better driveability
· Improved fuel economy
· Protects against exhaust valve seat recession (VSR)
- Aug 2011
- 7
August 24th, 2011 04:14 PM #28
- Jun 2011
- 198
October 8th, 2011 09:30 AM #29Premium = 93+ ron
XCS = 95 ron
GOLD = 95 ron
mga sir ask ko lang ano po mga color nang gas na ito? red or violet? a newbie question lang po.
kasi last time nag pa gas ako tinanong ko kung anong color nang gas violet daw tapos sa ibang station nag tanong din ako red naman daw? kaya medyo confusing po
October 8th, 2011 10:26 AM #30
If your car has a compression ratio of about 9-10, it better that you use ordinary unleaded fuel with RON of 93. If you have a ride that has 10.1 and up compression, it's good to have a 95 and up RON rating fuel in the gas tank.
Octane rating - Wikipedia, the free encyclopedia
Octane rating or octane number is a standard measure of the anti-knock properties (i.e. the performance) of a motor or aviation fuel. The higher the octane number, the more compression the fuel can withstand before detonating. In broad terms, fuels with a higher octane rating are used in high-compression engines that generally have higher performance.
Octane rating does not relate to the energy content of the fuel (see heating value). It is only a measure of the fuel's tendency to burn in a controlled manner, rather than exploding in an uncontrolled manner. Where the octane number is raised by blending in ethanol, energy content per volume is reduced.Fasten your seatbelt! Or else...Driven To Thrill!
For a 7-seater under 1 million, the Suzuki Ertiga is definitely one of the best options — it’s...
Best car worth 1million and below
