Results 1 to 10 of 16
September 22nd, 2010 10:18 PM #1
Lets say we have 2 SUVs with the same engine and the only difference is one a 4x4 and other a 4x2. Does the 4x4 SUV have higher fuel consumption if set to 2H as compared to the purely 4x2 SUV?
Thanks.Last edited by roydok; September 22nd, 2010 at 10:20 PM.
September 22nd, 2010 10:42 PM #2
- Dec 2007
- 37
September 23rd, 2010 12:35 AM #3Sir the 4x4 would always have a higher consumption. This is due to the added weight of the transfer case, diff and other stuff. Aside from the load, the 4x4 would have a larger driveline drag.
September 23rd, 2010 05:51 AM #4
Aside from the added weight of transfer case, differentials, etc... is there any resistance even if its set to 2H (2WD) that may affect the fuel economy? Or is it very negligible as the 2H setting is similar to a plain 4x2 configuration?
Thank you very much.
September 25th, 2010 05:44 PM #5
It depends on how the 4x4 system disengages (if just at front or both front/rear portions).
In any case, resistance is not that big but the problem is rotational inertial of the transfer case, diffs, shafts can add up. Much like upsizing a car's wheel from 15s to 18s while maintaining the wheel's overall diameter. The added inertial of the heavier wheel will add to the car's overall fuel consumption.
September 26th, 2010 04:26 PM #6
For some systems, the extra drag when 4WD is disengaged is minimal... but the weight is still there, and that has a big effect on economy and performance. It's like having an extra passenger on board at all times.
September 26th, 2010 04:34 PM #7
No contest, 4x2 is more fuel efficient. The 4x4 system has an extra set of axles, diffrentials which add weight even if they are not used.
September 26th, 2010 04:40 PM #8
I guessing your referring to 2H mode of the super select 4wd, wala naman siguro. kasi when I drive on 4H then turn to a curb there is resistance. pero pag 2H wala naman, besides its mechanical so a complete disengage is necessary. Sa FC meron talagang pag kakaiba around .5 to 1 km/L est. ko lang
September 26th, 2010 05:22 PM #9
sa 250x ko.. given na all-mode AWD may 2wd mode, mas matipid sa consumption pag 2wd mode.
pag "auto" mode, medyo matakaw nga lang sa consumo--around 1-2 km/l depende sa traffic. pag auto mode kasi AWD lang kung starting acceleration and if there is slip.
ang gusto ko lang sa "auto" mode is sporty ang drive.
so far, di pa ako nag-lo-"lock" mode.
September 26th, 2010 06:11 PM #10
But Id rather prefer driving my 4x4 rather than a 4x2. Roads here in the provinces are horrible.
Is the eMax 7 battery (Pure EV) a newer blade battery than sealion 6? I know one is hybrid and the...
BYD Sealion 6 DM-i
