Results 1 to 10 of 13
- Sep 2010
- 70
March 11th, 2011 06:33 PM #1good day mga fellow friends..
sir just want to ask your opinions regarding fuel additives(STP for example or other brands),i'm planning kasi to give a try of those fuel additives in my car (toyota xl 94 model)i'm thinking kasi baka makatulong in reducing the build-ups in the engine as the product says..any opinions po ba?would it really clean or reduce the build-up in my engine?is it safe?would it really save gas though in a minimum ways?..have anyone here tried already in your car?anu inputs or experiences sir? just want to ask muna sainyu sir before i give it a try to my car...
thanks a lot in advance friends...
March 11th, 2011 07:31 PM #2
March 11th, 2011 09:21 PM #3
It definitely WORKS...
...ON making you buy it and giving no effect on your engine!
- Sep 2010
- 70
March 12th, 2011 09:54 AM #4good day!
ganun po ba sir? i thought it's effective because it's from a good product,though my car is well maintained naman in my oil change, i'm planning to buy na sana those fuel additives for much effeciency and use it in my carthanks a lot sir for your information..
- Jul 2008
- 935
March 12th, 2011 10:03 AM #5[SIZE="3"]Just invest on a good engine oil...
Badtrip pa nga yang STP kasi gumagamit kame niyan dati sa lumang sasakyan
sa kada change oil...lumalapot nga yung oil pagkatapos mo ihalo...Siguro
kung may mga oil leaks or kumakain na ng konting oil yung engine mo
pwede sigurong ihalo...
But I still won't put any additives with my current ride...Just use a good oil...a synthetic one...[/SIZE]
- Sep 2010
- 70
March 12th, 2011 12:34 PM #6Sir what can you say about:
- Petron Octane Booster
- STP Fuel Injector & Carburetor Treatment
- STP Gas Treatment
STP GAS TREATMENT
Improves the quality of gas and keeps fuel injectors and intake valves clean.
STP® Gas Treatment improves the quality of gas by adding powerful cleaning agents that help fight the accumulation of harmful carbon, gum and varnish deposits in the fuel system that can reduce performance. Also engineered to remove water, which can lead to fuel line freeze. This product is made with jet fuel, a high-quality carrier of active ingredients.
Regular Use Helps
- Boost the cleaning performance of gas
- Save gas by keeping fuel intake system clean
- Fight fuel line freeze by removing water
Usage Frequency
Use regularly when you fill up
Take Note!
STP® Gas Treatment is safe for all gasoline engines.
STP FUEL INJECTOR & CARBURETOR TREATMENT
Fights deposit buildup and helps keep fuel injectors and carburetors clean.
Without cleaning, deposits can lead to hard starts, lost acceleration and rough idling. STP® Fuel Injector and Carburetor Treatment is specially formulated to maintain clean performance of fuel injectors and carburetors by helping prevent accumulation of deposits. It’s made with jet fuel, a high-quality carrier of active ingredients.
Used regularly, helps
- Save gas by keeping fuel injectors and carburetors clean of harmful deposits
- Prevent power loss
- Reduce engine friction
- Maintain optimum engine efficiency
Usage Frequency
Use regularly when you fill up.
Take Note!
STP® Fuel Injector & Carburetor Treatment is safe for all gasoline engines.
March 12th, 2011 02:22 PM #7
- Sep 2010
- 70
March 12th, 2011 02:53 PM #8
March 12th, 2011 06:08 PM #9
- Jan 2011
- 100
March 13th, 2011 03:09 AM #10
Otoh, the 2nd gen mu-x slightly looks like a mazda up front and some interior bits as well but oto...
2022 Mazda BT-50 (3rd Gen)
