Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Aug 2004
    Anybody could recommend a Diesel Mechanic and/or shop. Someone who preferably has overhauling experience of Trooper engines. Quezon City area sana. thanks
    Mar 2003
    sir Jai san ka sa qc? meron dito sa may diliman sa maunawain st.. puro suv halos ginagawa nya medyo mataas sumingil pero garantisado nman ang gawa... u can contact him at this number..09194955052 just text him for inquiries sabihin mo nirefer ka ni luwi.. after nya gawin oto mo bka di mo na makilala engine prang brand new....try mo sya kontakin sir....
    Mar 2003
    joy nga po pla ang pangalan nya... katatapos lang gawin pajero ko prang brandnew engine ko ngyon sir......
    Aug 2004
    Luwi,
    salamat, cge will get in touch with him. kaka pa comp test ko lang, ok pa pala makina ko kailangan lang adjustment of valves baka sa kanya ko na pagawa.
    thanks
    Jun 2005
    Sir jai,
    saan po kyao nagpa comp tes and how much. Salamat po.
    Aug 2004
    docvic,
    Sa Betan sa Makati. P500 but you have to leave your car the day before as the comp test has to be done on a dry manifold.
    Jul 2004
    Iwulpurong, What specifically the problem you have had with your Paj which Joy (Pajero expert) fixed?
    Mar 2003
    nabalian ako ng crankshaft bolt kya napilitan ibaba makina ko buti di inabot crackshaft kundi mas malaking gastos...whew..
    Quote Originally Posted by iwulporong
    sir anong engine po ng pajero niyo? 4d56 or 4m40? i might be needing an overhaul na rin for the 4m40 as JeF of mymitsu suggested since yesterday sa pajero clan EB, he took off the oil cap and had me idle the engine and a lot of oil splattered out from the open hole. how much inabot niyo and how long would it take?
    nugundam, diba normal lang that the oil will splatter when the engine is running or idling when you take off the oil cap. what i think is bad if there is smell of exhaust gas and smoke, its a sign of blow by na or the combustion passes thru the rings already. If wala ka pang oil consumption the engine is still good.
    What other symptoms have you experienced? diesel engines as long as regular change oil lasts up to 200k without a need for overhaul, and as long as hindi na overheat.
Diesel Overhaul Specialist
