Results 11 to 17 of 17
January 14th, 2011 11:00 PM #11
roughly correct but your nose is not precise enough to measure how lean or rich your air-fuel mix is.
Actually, it only happened with the Bosch regular temp platinum plugs. Never with the other plugs. The sound would be only single pops. It sounds more like a 'triangulo' and it happened twice yesterday while accelerating along SLEX.
Been driving car the whole day yesterday. No problems until I was on my way home. The only thing I can think of is that the car has been in use for 2+ hours.
- Dec 2008
- 105
January 14th, 2011 11:09 PM #12
January 14th, 2011 11:20 PM #13
- Dec 2008
- 105
January 14th, 2011 11:53 PM #14
January 25th, 2011 01:32 PM #15
Right now i'm using the NGK BKR GAS which is designed for LPG and CNG vehicles.
Its running well with FC still consistent when i was using BKR6E-GPs however i noticed the car hard starts when i run it on gasoline for extended periods.
Saw NGK BKR7E's (two step colder than stock) so i'll try these out just as well on my next plug change.
- Sep 2009
- 23
February 15th, 2011 01:25 PM #16Nakakita na ako ng Bosch platinum spark plugs on a daily driven taxi na after six months of using lpg sira na ang negative electrode ng spark plug due to acidic type of corrosion. Same thing will happen to upper cylinder block over time, mas mauna nga lang ang spark plug. Such corrosion did not happened to gasoline engines. It is a fuel combustion by product issue and not a fuel-air mixture issue.
Ask an experienced mekaniko or visit their shop, those who have serviced cars running lpg, they will tell you the real story about cars using lpg. Other than health problems experienced by taxi drivers using lpg, this corrosion issue is a big problem for car owners.
Fortunately, nag sulpotan na ngayon ang mga spark plugs for LPG use.
example:
http://www.bosch.com.au/content/language1/html/6578.htm
Unfortunately, the upper cylinder block replacement ay hindi madali mahanap unless daming surplus na pumapasok. Kahit meron mang supply ng upper cylinder block, it is not still practical to have it replaced from time to time.
Did anyone question about the quality of lpg fuel used for cars here in our country? I hope someone will.
February 15th, 2011 02:47 PM #17
I am still more convinced that the so-called corrosion is actually pitting caused by detonation due to improper air/fuel mixtures. Richer mixtures should prevent this.
BTW, lean air-fuel mixtures does generate more NOx which results in higher than normal nitric acid during combustion. Given that taxi drivers have a bad habit of adjusting their LPG systems to running leaner than normal, I would not be surprised if taxi units encounter this problem more than privately owned cars.
Will wonders never cease with Motolite? Ha ha.
