Results 21 to 30 of 111
February 15th, 2008 01:43 PM #21
Paring Edwin,
Php 7500 sabi niya Mura na yon kasi walang shiping, taxes(3k ba namn hingi sa akin, loko ba sila!!) and no wait.
Inimbita ko si Carl C. yung bumili ng mags ko to come and bring friends. Ikaw invite mo cousin mo. EB na tayo. Dagdagan mo na baon mong cash para pang happy happy natin.
February 15th, 2008 04:48 PM #22
February 15th, 2008 05:29 PM #23
You can control how much power you decide to add by adjusting your mix, less alcohol less power but even with strait water you will see a nice gain.
Stage one is a boost activated kit, you set the psi or bar you want it to come on at and it will activate the system at that point at 100%
Stage 2, is a progressive controller kit, The controller takes a 5 volt reference source such as a manifold air pressure sensor, throttle position sensor or mass air flow sensor and increase the amount of alcohol sprayed in proportion to that, It give you alot more control over your system.
Turbo diesels work very well with both, You can always upgrade your kit later but for now I would stick with the stage one because it is pretty much bullet proof. There is no telling the voltage range of your sensors our unit is based on the GM 2Bar and 3bar scale. If your sensor read different voltage the system will not work correctly. Besides we will have a new controller that is comming out in about 2 months.
Stick with the stage one for now.
February 15th, 2008 11:52 PM #24
1. 4JG2-TC
2. diesoline
3. batosai
4. niwde11
5. 20vanda01
6. ADAMSAPPLE
7.
8.
9.
10.
Four more to go!
I think peeps from Pampanga, Bulacan and Nueva Ecija are monitoring this thread, lucky them they dont have to drive from Manila.
Hope we can invite Turbo to come so we get to meet the "man"
February 16th, 2008 09:23 AM #25
Pwede ba sumali? Di ako tester pero kasama sa crowd lang.
iam3739.com
February 16th, 2008 11:13 AM #26
Drey,
You are most welcome, just sign up to confirm your attendance.
March 22 1pm Clark Field Pampanga.
Invite your turbo diesel friends.
February 16th, 2008 05:16 PM #27
Some questions on how to order came up. thought I would put it on both post so it gets addressed.
Just sign up on the site www.alcohol-injection.com
You will be ordering the Universal Stage 1 kit (Low boost) 2-12psi
or the High boost (12-30psi) kit
DO NOT ORDER THE DIESEL KIT (That is for US version TDI engines only)
In the comments section put (M2-M3-M5 NOZZLES) This range covers all passenger vehicles there)
Once you get to the check out and after the card info is entered, Put in the code: salamat and hit redeem this will auto adjust the Price and shipping to the discounted price. the proceed with check out. Paypal is not excepted from the PI on the site because of the security settings.
PAYPAL USER
Send payment of 195USD to sales*alcohol-injection.com
Subject: Philippines group buy
In the comments section : Universal Stage 1 kit M2-M3-M5 nozzles
Code: Salamat
February 16th, 2008 10:05 PM #28
1. 4JG2-TC
2. diesoline
3. batosai
4. niwde11
5. 20vanda01
6. ADAMSAPPLE
7. Trekker_1967 (will buy kit)
8.
9.
10.
- Jan 2005
- 23
February 17th, 2008 01:42 PM #29
February 17th, 2008 08:35 PM #30
more install pics so you can see the quality of our parts. We use all nickel plate brass which will last a lifetime. This is a picture of the nozzle holder and our custom 16psi check valve.
The 12-month warranty on the factory battery ended a few days ago. SOH is still good at over 90%,...
