Results 1 to 10 of 53
- Jan 2009
- 60
October 14th, 2012 02:25 AM #1anu po dito sa dalawa na to ang magandang feature, low maintenance, less issue, pangmatagalan po.
meron po kasi kaming navara benta namin kasi of high maintenance. thanks in advance.
- Mar 2011
- 337
October 14th, 2012 04:12 AM #2Hilux kana sir
pero kung makakaantay kayo next year
syempre DMAX
o kaya try nyo pasokin ang dalawang SECTION TOYOTA at ISUZU
may mga thread nman yang mga yan
basabasa na lang po kayo sa mga Feedback ng mga Owners of both PICK up
baka makatulong po sa inyong pagpapasya
- Oct 2012
- 5
October 17th, 2012 03:57 PM #3Open Suggestion pa ba sir Or naka pili na kau ng Best Pick up nyo sir..
For me sir see my Avatar.. he he he Pogi.. MT12model.
October 20th, 2012 03:31 PM #4
High maintenance ba ang Navara "Hi-Power" sir? Gaano ka mahal ang maintenance sir?
Between the two sir at the current times, go for the Hilux 2.5 VNT.
However, if you can wait and hold on more with the Navara inspite of its high maintenance cost, as you said, wait for the Ranger 3.2 TDCi straight-penta cylinder. For me, it's better to have a bigger displacement with less reliance on boosting, unlike what is the prevailing trend now (small engine that relies much on boost from turbocharging) ....It is also better to have that extra-displacement when you need it most than you don't have it at all in time you need it.
The Ranger 3.2 should be an excellent package, it being a straight-5 cylinder (throws in the crank are relatively closely-spaced) therefore it runs smoother than any 4-inline cylinder pickups that you see in Philippines at present, among many other things. It doesn't use any balancing shafts that robs off a certain degree of power from the engine that you would normally need in an inherently imbalanced 4-inline and V6 engines, as the straight-5 engine is already balanced.
As far as i know, Volvo is the other manufacturer that makes straight-pentas these days aside from Ford. The other engine that is even smoother than the penta is the straight-6 cylinder that BMW still makes, or the V12 as it uses the straight-6 crankshaft.
Based on recent reviews of this utility pickup and on 4x4 pickup comparisons in other countries such as Australia (where it was developed by Ford Motors - for the outback settings e.g. hauling, top-towing, flood-wading, rugged handling etc, but giving you the level of comfort both on- and off-road), it's the best pickup available at any price-point.
Cheers and goodluck sa endeavour ninyo sir as a family!
October 21st, 2012 11:02 AM #5
October 21st, 2012 11:28 AM #6
October 21st, 2012 12:56 PM #7
Do note that the 3.2 Ranger will probably be launched some 300,000 pesos more expensive than a Hilux 2.5 G or other equivalent pickups. It will also consume more diesel by virtue of its larger displacement and higher cylinder count.
The downside of having displacement when you need is that during the times that you just need a sedate truck, you still pay for higher fuel bills.
October 21st, 2012 01:02 PM #8
October 21st, 2012 03:00 PM #9
Sir any information when Ang release Ng all new D-max? I think same platform soya Ng Colorado .
i do not know about your car, but when my non-honda solenoid failed, the mechanic just replaced...
starter solenoid failure
