Results 21 to 30 of 35
February 18th, 2007 08:52 PM #21
5.8 seconds to 100 from the Si? Now that's too much truth-stretching. A mid-6 time should be more realistic.
For everyday driving, the Si should be easier to live with. It has a nicer dashboard, a better sounding engine that should use less fuel than the WRX, and should also have a better ride. I'd choose the WRX if I'm at the track often. But although 4WD has better front grip than FWD, the WRX is still notorious for understeer, unless it's equipped with the torque adjuster, which can transfer upto 2/3 of it to the rear wheels.
February 19th, 2007 11:41 AM #22
I think the new active differential should cure some of that understeer... but the autocross boys on the Mazda board say that the WRX is a lot more understeery through the cones than the Protege/Lynx.
The Si should prove to be fun through the autocross, a bit lighter, LSD, and sharp steering... but I'm still wishing on a Jazz Si or Type R... that baby does the 300 ft slalom at over 70 mph... one of the few "cheap cars" besides the Protege that has done that in "stock" trim.
But a Jazz or Fit-R would be pricey... 200 hp K20s are still at around 200k+
February 19th, 2007 12:56 PM #23
^^a beefier rear sway bar and light suspension mods should do the trick in eliminating that understeer.
OT: Protege's are really fun to drivei used to have a slightly modded 03 Protege 5
February 19th, 2007 03:12 PM #24
I was going to say a lighter front... but a beefier rear does make more sense. :tup:
*sigh* Protege5... too bad they never brought in the Aussie version here (Ford Laser/Lynx 5-door with the 2.0)... seriously OT... hehe... just love the car.
- Feb 2007
- 103
March 6th, 2007 01:09 AM #26still not a proper match for me.. WRX all the way!.. Maybe a 200hp sentra SE-R spec-v or the euro car that has jap import like characteristic- the volkwagen GTI woul be the better match for the Si. ;)
March 6th, 2007 12:19 PM #27
still close, it wolud have been different if the SI is turbo.
www.edmunds.com top 5 sport compact sedans
1. mazda speed3
2. wrx
3. civic si coupe
4. volks gti
5. chevy.....(i forgot)
- Feb 2007
- 103
March 6th, 2007 11:17 PM #28he he... exactly!! if only d Si had turbos... but it doesnt. Oh and by the way other websites had different rankings all together, and those rankings changes almost every 2 days. And the 200hp sentra SE-R spec-V nga pala had to be launched pa pala in summer in the U.S. this 07. Oooops.
March 7th, 2007 01:18 AM #29
Remove the WRX from that list and put in the up coming SE-R and you'd have a more equal comparison because all will fwd.
Mazdaspeed 3, 2.3L turbo, 263hp/280lb-ft
Civic SI, 2L, 197hp/139lb-ft
VW GTI, 2L turbo, 200hp/207lb-ft
Sentra SE-R V Spec, 2.5L, 200hp/180lb-ft
Chevy Cobalt SS, 2L Supercharged, 205hp/200lb-ft
As you can see the Civic falls far short in terms of torque which is what you need to accelerate. The Mazda AFAIK is close to what the stock internals can take at it's current boost level. The GTI can put out more hp with just a chip and isn't even close what the stock internals can take. Sentra is most likey at it's max as a normally aspirated motor. Cobalt can be bought from the dealer with stage 1 or stage 2 kits to make it put out 270hp with a manufacturer warranty.
Horsepower wise they can come close to a WRX but handling will be another story all together. The limitations of fwd vs awd is what makes the WRX a better vehicle. I drove my nephews Vishnu modded WRX with the 2L boxer which was up to STI territory in horsepower. I still can't believe the speed I was able to take corners in that car, only the EVO we test drove comes close. The acceleration was even more amazing with 2nd gear good for 70mph=112km/h and that was still with the stock turbo. Too bad he sold it for a BMW 3 series.
Heres a comparison made with some of the cars mentioned above.
http://www.automobilemag.com/reviews...ars/index.html
March 7th, 2007 02:49 AM #30
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
