Results 1 to 10 of 30
- Oct 2006
- 148
February 16th, 2020 05:34 PM #1Mga Sir need ko po ang expert advice nyo. I'm planning to buy a new car to supplement my old but reliable Honda Jazz. Below are my requirements/specs:
1. 7 seater -for family use
2. Maximum budget of 1.8M
3. Comfortable
4. Large cargo space and can carry heavy loads
5. Handling/easy to drive
6. Reliable and with no major mechanical/technical issues
7. Design and features (safety,tech,gadgets)
I'll use it as my daily drive going to work and also as cargo hauler (around 600 kilos plus two people) whenever we get supplies for the small business of my wife, from Central Luzon to Manila at least twice a month. My old Jazz is having a rough time whenever we buy supplies from Manila. Also, I haven't experienced driving a larger vehicle like SUV/MPV, mostly sedan lang na-drive ko, so ease of use and comfort is also an importanr consideration baka kasi manibago ako. Thank you po sa response.
February 16th, 2020 05:41 PM #2
Among those options, the crv is the closest you’ll get to having a sedan like drive and being a “7” seater.
But if people hauling is important you might be better off with the terra, innova or monty.
Innova is the most practical with a 2.8L, toyota reliability, and adequate clearance and good space but if you want that suv look of course monty or terra.
Personally though I’d choose between the Innova and the Montero
- Jun 2005
- 3,774
February 16th, 2020 07:08 PM #3Innova for practicality.
But know that the current nodel's achilles heels are the stock tires and shock absorbers.
My 2019 innova with 5k mileage has signs of busted rear shocks
Sent from my MI MAX 2 using Tapatalk
- Apr 2008
- 6,235
February 16th, 2020 07:52 PM #4Since carrying heavy loads is a priority, better choices would be the ladder frame options. The Innova is actually the most versatile since it has the shortest hood, with most of its body length allocated for cabin space.
Since you will have lots of savings from your 1.8M, as mentioned you may use it for suspension and wheel/tire upgrades.
An option you may to consider is the base Kia Carnival at 1.995M. Absolutely endless cargo space if you remove the 4th row (which will still leave you with 8 passenger capacity). Since it is designed to carry 11 passengers, payload capacity is not a problem. The 2.2 is also proven worthy across many Hyundai and Kia models in the last ten years and is still one of the most powerful in the market.
Sent from my SM-G965N using Tapatalk
- 54,198
February 16th, 2020 09:37 PM #5
- Aug 2017
- 321
February 18th, 2020 01:24 PM #6
February 18th, 2020 02:52 PM #7
Innova if you want the highest practicality and durability at the lowest price. Terra if you can afford to splurge a little.
Both will be ok for hauling cargo. A bit less refined to drive vs a sedan but you'll get used to it. Key difference is that the Innova is an un-s3xy family car, the Terra is a more macho SUV.
Sent from my SM-N970F using TapatalkLast edited by jut703; February 18th, 2020 at 03:01 PM.
- Feb 2020
- 420
February 18th, 2020 03:15 PM #8
- Apr 2008
- 6,235
February 18th, 2020 04:29 PM #9If you don't mind driving a manual, I just remembered that the Hiace Commuter Deluxe is just 1.6M... Load all you want! [emoji16]
- May 2019
- 312
February 23rd, 2020 02:57 AM #10The Innova would be ideal for your needs as as a family hauler/business vehicle.
One can only hope.
