Results 41 to 50 of 52
May 16th, 2020 04:42 PM #41
The B18C is rated at around 200hp and if paired with a small sedan frame will be more like a BRZ/86 in straightline performance. Someone posted above of his Sorento against an 86 and the disparity in weight was the clincher in favor to the 86.
May 16th, 2020 04:55 PM #42
The civic 1.8L is adequate, a little underpowered even. I can think of some subcompacts which can beat it easily. The civic with the 1.5L turbo though, now that's quick. Too bad it's overpriced as hell.
May 16th, 2020 05:45 PM #43
I don’t think the Civic 1.8L is underpowered. What more for the likes of other compacts with 1.6L or 1.5L NA engines? Most subcompacts are around the same in performance (or even less) except for the quicker ones like the Fiesta Ecoboost, Accent CRDi, and Mazda2 HB.
May 16th, 2020 06:46 PM #44
A bit underpowered for a car which has a 1.8L I mean. Take note of the word “bit”. Di naman gaano...
Anyway, sa Civic FD dati, pwede but for the newer body with heavier weight, sana 2.0L na lang. Also... everyone keeps forgetting the City and the Jazz with a manual transmission can probably outrun the Civic 1.8L. But I get the point, di naman pabilisan talaga ang purpose. For a point A to point B car, I believe it is adequate.
- Jul 2009
- 2,618
May 16th, 2020 07:29 PM #45
- Jul 2009
- 2,618
May 16th, 2020 08:04 PM #46
May 17th, 2020 01:35 PM #47
seeing this race is like seeing the F-150 vs Cyrbertruck tug of war
not an expert, but I always find Toyota's max rpm/power around 3-4k rpm... compared to Honda na around 5.5-6.5k rpm - this can normally be felt when overtaking in local provincial roads. - hence during HS days... mas madaling "paiyakin" ang Toyota
2nd... if you keep on racing both... I don't think the Innova's diesel engine will last as long as the Honda's Petrol engine... pero mauuna sigurong masira yung CVT than the conventional A/T
3rd stopping power... being a racer sa Mindanao and Macapagal YEARSSSSS ago... I'll be more confident stopping on a Civic than an Innova kapag may biglang car na sumulpot sa harap mo.
4th handling... I always prefer to drive a car because of this reason, faster/better cornering
5th... pogi factor... I will always say mas pogi yung car... my dad will say kasya 6 na chicks sa MPV
quick question na matagal nang nasa isip ko...
Innova uses a de-tuned 2.8 engine thats the same as the Fortuner.
Can you swap the computer box of the Innova to get the Fortuner's power? - kahit sa sites ng Toyota Malaysia/India/Indonesia wala akong makitang info on this.
- Jul 2009
- 2,618
May 17th, 2020 01:47 PM #48
May 17th, 2020 01:59 PM #49
Most Diesel engines achieve peak power around 4k rpm while achieving peak torque between 2k to 4k rpm. It applies to most car manufacturers, not just Toyota. Most Diesel engines are limited to 5k rpm. This is the reason some people would say that a diesel feels quicker as peak torque is readily available at lower rpms.
For NA engines used in most small cars and crossovers, peak torque is achieved at 4k while peak power is reached at 6k rpm (just below redline). Some NA engines which have redlines of 8k rpm will have its peak power at 7k rpm. There is no point trying to eke out performance from a gas NA engine if you are scared to rev it past 3k rpm.
For turbo gas engines, peak torque is achieved between 1500 to 5k rpm depending on manufacturer. Peak power is available from 5k to 7k rpm depending on the engine. If you aim for performance, this is the best option as you get peak torque on a wider rpm band plus higher power output, not to mention the more ways to tune its ECU. Just consider Merc’s 2.0L turbo gas engine which has peak output of 415hp/500Nm, that’s a lot compared to older engines which has twice the displacement.
May 17th, 2020 02:01 PM #50
hmmm... specs sheets
Innova 2.8
171 / 3,400
360 / 1,200-3,400
Fortuner 2.8
174 hp / 3,400
450 / 1,600 - 2,400
so Fort has higher torque at lower RPM...
I wonder if anyone has tested these figures sa dyno
I feel the same way. Not a fan.
2022 Mazda BT-50 (3rd Gen)
