Results 21 to 30 of 73
- Mar 2003
- 33
March 10th, 2003 01:59 PM #21Thank you for all of your feedbacks. I decided to go for the MB100.
I'm looking for a CMC model with ending plate numbers 3,4,7,8,9 or 0, 1st owned, preferrably silver, but any color will do, except white, well maintained and direct seller.
Maybe you guys can refer some sellers.
- Dec 2005
- 20
December 26th, 2005 11:57 AM #22huwag ng MB100, go for other vans(starex or jap vans na lang). Sobrang mahal ang maintenance and parts. At sasakyan lang iyan ng mga sobrang yaman na tsinay. My ate is a teacher at ica greenhills. Pag sinusundo namin siya, panay MB100 ang van ng mga ultra wealthy students nila. I guess these people can afford the very expensive maintenance cost and parts kaya iyang MB ay makikita mo lang lagi sa makati at greenhills (area ng mga wealthy chinese families). Stick with the starex na lang or the Hi-Ace...iyan ang van namin kasi and mas mura ang parts.
December 27th, 2005 10:56 PM #23
Just scout the ads. CMC units are pretty easy to find. And by this time, anything that needs fixing would have been fixed by the previous owner. If not, the low resale value guarantees that you will not go anywhere near the price of a brand-new MB100 even if you have to fix lots of stuff.
CMC:
*CMC badge on radiator support bracket
*Small side mirrors
*Small MB emblem above the grill
*Non-rotating (but reclining) bench seats on row 2-3 with split folding bench on row 4
*Mercedes logo on steering wheel
*No inside tailgate release handle
*Manual dual a/c
*Bigger radiator
*Shorter axle gearing
Recalls:
*Reinforced door handles (inner mechanisms replaced with metal instead of plastic)
*Revised air intake system
*Revised a/c pipe routing
Improvements along the line:
*Heavier flywheel (quieter)
*Improved a/c system
*Shifter redesigned with more robust components
December 28th, 2005 06:09 PM #25
for the MB100...
how does the engine drive the front wheels, transverse shaft from the tranny then may differential? (curious lang)
April 29th, 2006 05:17 PM #26
I'm planning to buy a 2nd hand van. Ano mas maganda, HiAce or MB100? ok ba parts availability ng MB100? parts cost of the 2? 2.5/2.8/3.0 na HiAce, is there a big difference in power, like in going up Baguio di ba bitin pag 2.5 lang engine? Alternate choices to these 2, ano recommended nyo? Starex? needs to be diesel.
intended use nga pala is "van for rent" business. any comments will be appreciated. thanks!
April 29th, 2006 10:10 PM #27
Both are okay vans, I guess, but the Hiace will definitely be easier to fix. The MB100 has a 2.9, so power isn't bad, but it's ass slow. I don't like the interior plastics, they're too easily damaged. The AC is good, though. The 2.5 Hiace feels weak in mountain climbing... but this only means slower ascents, not an inability to climb at all.
April 29th, 2006 10:14 PM #28
The Starex is a nice choice, also, but a Hiace is an ideal rental vehicle. Only problem is non-Subic secondhands cost an arm and a leg. I should know, my cousin is selling one.
April 29th, 2006 10:52 PM #29
may natignan na nga kami na 2 units na subic hiace, 2.5 A/T (320k) and the 3.0 A/T(390k). ganda sana kaso nga nasa left side yung sliding door. ok lang sana sa akin na converted kasi balak ko naman na baguhin lahat ng steering parts, kaso lang hindi yata pwede palagyan ng door sa right side ehehehehe. kung pwede lang e di ok na ok sana 2 sliding doors di ba, kaso di daw pwede. saka yung subic versions na nakita ko e puro 7 seaters lang (2 captains+2 rotating captains+3 folding).
hanap ko talaga yung local version na 3.0L, 11/12 seater. try ko sa mga banks baka meron repossesed na units. ano ba usual price ng 2nd hand units?
Tsikot Member Rank 3
- Aug 2003
- 1,251
April 30th, 2006 12:00 AM #302.4L 2L hi ace is the choice among van rentals. Its more economical in terms of maintenance and fuel economy than the 3.0L engine in the grandia.
Isuzu pala makina, at least madali hanapan ng parts.
2022 Mazda BT-50 (3rd Gen)
