Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
    Mar 2011
    #21
    ÓT: Ano mga sasakyan ngayon na naka:
    1. Chain Drive?
    2. Belt Drive?
    SUVs, AUVs, MPVs, Pick-ups!
    Cguro naman Cars or Sedan bihira lang.TY.
  2. #22
    research ka nalang dami e!
    #23
    Quote Originally Posted by S.S.C._28 View Post
    1. Chain Drive?
    2. Belt Drive?
    AFAIK (timing chain)... isuzu crosswinds, vvti engines (vios, altis), suzuki vehicles, 4M40 mitsubishi, series 3 sentra
    (timing belt)... d4d toyota, most hondas
    Aug 2004
    #24
    The Crosswind is timing gear, not chain.
    Mitsubishi gas engines are chain.
    Modern timing belts last around 60-100,000 kms. They usually give you no trouble if you follow the change interval. Some manufacturers still use them because they're quieter than chain drive.
    #25
    +1, mas tahimik nga belt driven.
    May 2010
    #26
    Kaya pala yung Honda Civic namin, maski 100kph, tahimik!! Eh yung Innova Gas, timing belt or chain??
    #27
    Quote Originally Posted by myk384 View Post
    AFAIK the innova gas engine uses timing chain.
    Aug 2004
    #28
    The nice thing about the clackety clack of timing chains. If it gets even louder, then you know it's time for replacement.
    Personally, I haven't seen much difference between the two in practical use, as long as you do maintenance regularly. I've had to replace the timing belt on my Lynx at around 60-80,000 kms... but I also had to have the timing chain tensioner replaced on the Sentra at around 60,000 kms.
    Yes, the chain is definitely safer. Yes, it costs a bit less to maintain. But no, it's not completely maintenance free. You still have to follow similar intervals, otherwise you risk breaking the chain. (I know of two or three instances of chains breaking from my time on the Nissan boards. It's much, much rarer than timing belts stretching and breaking, but it still happens.)
    Oct 2007
    #29
    AFAIK belt is more economical to operate because is lighter to spin than chain thats why most engines use timing belt.
    Feb 2009
    #30
    timing belt driven valve train has its merits:
    1- it is lighter
    2- it is quieter
    3- when it is time for periodic maintenance, the timing belt and associated parts are external and accessible
    timing belt driven valve trains have disadvantages:
    1-car owners usually don't maintain their cars as what is recommended by the manufacturer
    2-when it breaks, it usually don't give warning telltale signs except the mileage(don't rely on this specially on city driving) and the engine is on clock hours not miles incurred.
    3-most shops and so are the car owners are not aware of the MAW (might as well parts) like the camshaft oil seal, crankshaft oil seal, timing belt tensioner, timing belt idler, timing belt driven water pump. they were installed on the same hour, same day, incurred the same mileage, exposed to the same environment. other than that, no car was designed to last forever.
chain drive or belt drive
