Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    It seems the new Bronco has proven it can go toe to toe with the Wrangler.
    What in the world was Land Rover thinking? Really? low profile tires?
    Dec 2019
    LR probably sees the new Defender is now a crossover SUV.
    Jan 2012
    LR has also turned the Defender into a lifestyle SUV
    They already have the Evoque for that role
    Dec 2019
    also the discovery sport and the velar..
    Jan 2012
    Just watched a bit of the video
    Seems like the Defender is disadvantaged by its its road tires
    The Bronco is impressive considering its on an Everest/Ranger Chassis
    IMO this review highlights the difference between real off-roader channels vs shills (like carwow). Obvious na sumunod sa review guidelines ng Land Rover.
    Yung mga test ng channels like carwow specifically choose scenarios (like that slippery but otherwise smooth muddy hill) that highlight the Defender's strengths (electronically controlled off-road traction control) while hiding its weaknesses (low profile tires).
    IIRC another problem with the Defender is that it's not physically possible to fit higher profile tires because the big brakes necessitate 18" wheels minimum.
    Dec 2019
    Quote Originally Posted by viper888 View Post
    The old generation Defender's wheel/tire combination is more comparable on the Bronco and Wrangler. Due to its truck platform (Body on frame design). Can be fitted with a beefier wheels and tires like the Jeep Wrangler and the Ford Bronco.
    This new Defender shares much of the chassis used in the current Range Rover. Which is unitized body. It also shares the big Range Rover's brakes that's why the current Defender requires bigger wheels and lower profile tires.
    Yung g class alam ko naka low profile tires din un pero super capable naman off-road kahit stock lang siya.
    the scraping sounds of this video is unforgettable. epic video from TFL again nonetheless
    I agree with Nathan, the Jeep is more capable. and its a rocket from 0 to 60mph.
Bronco vs Wrangler vs Defender | TFL Offroad
