Page 5 of 10 FirstFirst 123456789 ... LastLast
Results 41 to 50 of 97
    Mar 2013
    #41
    120 hp is more than enough. You can drive to ilocos and back no problem. I remember the time when the first 16valve corolla with 95 hp was considered extremely fast. Also the 300nm of torwue for the crv comes in really early. So you will have a lot of pulling power.
    If you dont intend to go past 160 kmh then the CR-V is very capable.
    #42
    Quote Originally Posted by lightsaberx View Post
    Okay, I can call myself confused at this point until after I have test driven the CRV. It's really hard to compare If you only have tested 1 out of the 2.
    Based on my initial post, I have provided several factors why I am considering both cars. I will break down those considerations in able to provide further information as to "why".
    I live outside the metro and is working in Ortigas. The road conditions are not 100% good all thoughout the year, the road breaks mostly during rainy season since large trucks traverses it after truck ban loaded with soil/rocks, precasted concrete, cement and others. Had several previous instances that soil and rocks from these trucks are spilled over the road and it skid under the car due to low clearance. But hey, the City conquered it, good thing no major under damage. There are also minimal floodings along the way when it rains real hard, therefore, 1 major criteria would be high ground clearance. But, I need to consider also the senior people riding it during out of town trips.
    In paper, the CRV has 198mm vs 218mm for the Monty. Is 20mm that huge of a difference? In person, it looks like the Monty is much higher than 20mm. A comment here says that entering the monty is hard, with the 20mm diff which is not very significant, can we also say that it will be hard to enter the CRV? This I have yet to try.
    Another major consideration is the engine power. The farthest I have driven the City is up to Baguio with 4 persons and several luggages. The 1.5L did okay but you can already feel the stress on the engine going up. I would want the car to be able to go further. I plan and dream to drive around with it as far as Ilocos, up Sagada, down Naga and Legazpi and maybe even roro to Mindoro, Samar and Leyte with maybe 5+ passengers.
    120hp/300 torque of the CRV vs 181hp/430 torque of the Monty. With engines, the higher the better?
    The minor considerations, there's the added feature of the Montero (Push button start, dual climate control, leather steering, better multimedia 6.75" 6speaker, 18" wheel) vs the security features of the CRV (hill start assist, stability control, leather seats, LED drl, tail lamp).
    Then there's the price. Montero costing lower of about 139K vs the CRV after discounts.
    You are leaning to Montero Sports, just buy it and it will make you happy. . Those people who wants the CRV let them buy it.
    Aug 2017
    #43
    Choose monty much better in a long trip kung out of metro pa ang pinanggagalingan mo papunta sa work.siguro you already test drive the 2017 monty.wait for the crv diesel variant to launch then test drive it and compare the two.nobody among us drives the new crv.pero for me monty is better.it can give you the power you want.
    Jan 2008
    #44
    Consider the drive train layout of the two.. montero is rear wheel drive compared to cr-v front wheel configuration.. that makes the cr-v roomier compared to the montero rugged heavy duty rear wheel drive
    Sep 2014
    #45
    actually hinde naman mahirap mag-decide coz even though PPV category ang Montero, it's the softrider among the 4 PPvS, in fsct sa sobrang lambot ng suspension nya, may mga nagpapagawa na sa casa ngaun na hindi na daw pantay ang car nila, check the Montero thread.
    so given that the Montero is softrider and the CRV is definitely softrider. talo ka lang magpalinis sa Montero kase may stepboard pa, eh wala din naman pala advantsge sa tough roads in the long run
    Jan 2014
    #46
    Montero as with other PPVs and pickups are sitting on ladder frames. So while ground clearance might not be much higher than a CRV, the body and engine are.
    Advantage is the higher water wading depth and approach, break-over, and departure angles (if you care about off-roading). Disadvantage is less interior space cos of the frame below the body, more noticeable body-roll due to the higher center of gravity. That's also why it feels like you're climbing inside a PPV vs stepping inside a crossover.
    Go for the Montero since it looks like you're somewhat decided already. If you can spend extra for the Premium or haggle a bit, you'll have no regrets since it looks like the added safety kit with the CRV is your only concern.
    Jun 2012
    #47
    Assume 7 km/L for the gas and 9 km/L for the diesel. Gas is at P45/L, diesel at P32/L. Average mileage of 15000 km per year.
    15k / 7 km/L x 45 = 96k gas per year
    15k / 9 km/L x 32 = 53k diesel per year
    40k per year difference if you compare the Gas S vs Diesel S variants with the same equipment level, price difference is 200k so you'll make up the difference in 5 years.
    Now if you don't mind the features of the S variant, then basically you save 40k per year on the V diesel vs S gas.
    Can you add projected pms per year and see long run how both diesel and gas stacks up? In case anybody knows pms cost or had experience.
    #48
    Quote Originally Posted by yecherchong View Post
    PMS difference isn't that big. Much of the cost difference is simply because diesel engines require more oil than gas engines - usually 8L vs 5L. So assuming you use FS oil at 500/L and have them changed twice a year, then that's 3k more annually for diesel PMS.
    My previous diesel vehicle (Ranger 2.2) cost me around 8k every 10k kms. My previous gas-fed vehicle (Altis 1.6) cost around 4k every 10k km and 2k every 5k km PMS so a total of around 6k every 10k km cycle.
    Fuel savings outweighs higher maintenance costs between gas and diesel.
    Mar 2004
    #49
    Just test drive both vehicles ... makes your decision much easier ...
    Sep 2014
    #50
    sigurado mas matipid ang CRV Diesel V and S dyan sa Montero kasi mas malaki gulong nyan Montero. My Hyundai SF crossover averages 10-11km/liter pure city. something na hindi na-reach ng mga PPVS ngaun average 8-9 km/liter lang. eh 235 lang gulong ko eh, eh sila 265
2017 Honda CR-V 1.6 V or 2017 Mitsubishi Montero Sport GLS
