Results 1 to 10 of 47
January 27th, 2011 08:24 PM #1
Worth the effort ba to restore a box-type Lancer? Mahirap ba parts? Would I end up spending a lot pero masakit pa rin ang ulo ko to make it roadworthy and reliable? Thanks.
- Jul 2009
- 40
January 27th, 2011 09:59 PM #2If you will restore this car for "hobby" purposes yes, but if your intention is to restore this car and plan on using this as a daily driver then no.
January 27th, 2011 10:11 PM #3
If it's for personal hobby, why not? But you should be prepared to spend more money than the car is worth.
If it's to use it as personal daily transport (to save money from buying a new/newer car), no, it will not be worth it.
BTW, if you are going to restore it, you will first have to take it apart, clean it up, fix up the chassis and install all the parts back, replacing worn out stuff as you go. It will be a long & hard process if you really want to restore the car to a roadworthy and reliable condition.
January 27th, 2011 10:38 PM #4
Not really for a daily drive. Will use it only for coding days plus once in a while trips in the city. The reason I want it to be reliable is that I don't like to have headaches or hesitations that it will break down whenever I'm driving it.
gh, its a good idea to strip it down but if I do, would you know of a ballpark figure I will end up paying to get it going? Say if the car is worth 30k, i don't want to spend a lot to bring it to mint condition. Just as long as its presentable and runs well, it would be good enough for me.
January 28th, 2011 12:38 AM #6
January 28th, 2011 03:04 PM #7
I have an eye on an A/T 1983 Box Type Lancer. This is very rare as I remembered i had a neighbor back then who owned one. Any suggestions by the old school gurus/box type afficionados here?
- Oct 2005
- 26
August 19th, 2011 08:07 AM #8kung for show or pang tago, prepare to spend at least 100k for everything. from body repair, lights, rubber fittings, etc. etc.
puwede rin naman on a budget. abang ka lang ng kakatayin na lancer box type near your area, pero in some instances, talagang dinadayo pa ang katayan ng mga lumang oto. pero take note that some parts are getting expensive, like the original stanley headlights and taillights.
may mabibilhan pang parts ang box type. mahal nga lang. pero mostly may taiwan counterparts like sa mga ilaw, rubber fittings, grille, etc. kaya puwede ka magtipid ng konti.
marami na rin napuntahan ang boxtype namin, as far as baguio city to the north and as far as tagaytay to the south. this is our daily driver.
the a/t boxtype needs extra attention and TLC on the cooling system. pero nothing out of the ordinary like radiator linis/overhaul, additional aux fan, coolant, etc. etc. ang oil cooler kasi nung A/T nakasakay sa radiator. this is very important especially pag puro paakyat ang daanan mo and/or madalas kang puno ng either passengers, cargo or both. a separate oil cooler na maliit (tulad ng sa mga bagong oto) is highly recommended.
pina overhaul na rin namin 2 years ago iyong transmission. overhauling kit may mabibili pa sa inyong suking mitsubishi specialty shop sa banawe (coltline, bestcolt, motorix, etc. etc.).
below are some general specs of the A/T boxtype
engine: 4g32 1600cc, same engine as with the GSR/GT variant
trim: SL model, loob at labas
transmission: 3 speed a/t
brakes: front - disc, rear - drum
August 19th, 2011 08:16 AM #9
^^^ Power steering na rin ba iyan, bro?
Used to own a box type lancer. Was mightily satisfied, until new cars with power steering came in.....
13.9K:mop:
- Oct 2005
- 26
August 19th, 2011 01:55 PM #10nope manual steering po. most early box types wala talagang power steering eh, unless pinakabit na sa labas. iyong mga late model boxes na lang ang meron.
nonetheless, madali lang naman pa power steering ang box type. steering gearbox and pump from L300 oks na siya. at siyempre iyong hydraulic fittings.
Toyota Sports 800 (1965 - 1969) behind the man at the start of the video. :nod: I wish car...
2025 Manila International Auto Show
