Results 281 to 290 of 918
May 2nd, 2005 08:13 PM #281
Medyo pricey nga yung bago kaya di ako makapag-upgrade, heheheh. Dun sa directed, try mo ding mag query sa kac.com. ok mga gurus dun.
- May 2004
- 27
May 3rd, 2005 08:41 AM #282[QUOTE=baurtwellXUV]-tots-
for spl po ba or sq ang set up mo?![/QUOTE]
sir sq po. pls recommend a shop, pls. include contact details. salamat po
May 3rd, 2005 12:32 PM #283
-tots-
san ba location mo para mabagy ko syo na shop na kung saan malapit sa area mo...
- May 2004
- 27
May 4th, 2005 02:42 PM #285
-tots-
how much will your budget for the set up?! you can go to auto circuit.. located at banawe...
- May 2004
- 27
May 4th, 2005 04:58 PM #286very limited budget 25k lang po including HU. kahit po yung pinaka-simple
sa set-up, kasya na ba ang budget ko?
- Apr 2005
- 16
May 6th, 2005 02:35 PM #287All stock (except audio) 98 Corolla XE, midnight blue.
Pioneer HU
Blaupunkt IC 165 XL seps in front (6.5", 120 Watts max each, I forget RMS, 80 ata)
Same seps on the rear
2 Blaupunkt TSw 300 subs (12", 600 Watts max each, sealed box)
Blue neon lights located at the rear of the subs inside the box.
V12 NV805 amp for seps (4 CH, 2000 Watts max daw)
V12 MRVF-450S for subs (4 CH, 3000 Watts max daw), 2 Ch lang ginamit, di pa ata brinidge
I am guilty of buying the setup all at once without studying the subject 1st. Now that I read the threads, I think (know) I made a LOT of mistakes. I just dunno were to begin.
Any suggestion on how to MAXIMIZE this set up OR how to improve the setup with minimal added cost (naka 30K plus napo ako) will be GREATLY appreciated.
Thank youLast edited by Khellendros; May 6th, 2005 at 03:27 PM. Reason: Questions stated are for another thread...Separates
May 6th, 2005 02:51 PM #2881.)I know V12's max power is overstated so I don't know if the wattages (?)match.
2.)IF, IF lang po, kasi ang mahal eh (10K), I change to Velocity seps, 350W max, do I need to change my seps amp? Nakalagay kse "500W X 4 Max Power Output" pero sa ilalim "150W/Channel RMS Continous Output * 0.5 THD (20Hz to 20KHz, both channels driven into 4ohms load)" Ano daw?
3.)I think my subs are fine, I think my seps are too weak (gumagaralgal pag malakas), I don't know if volume is too strong, the amp is too strong, or the seps are weak. (I'm hoping it's not coz I'm going deaf).
4.) Do I really need seps at the rear? I plan to sell all my seps, buy a good pair and probably reinstall the stock rear speakers. OR do I need to realize that I'm lucky enough to have aset up in the 1st place and be contended with what I have and just have it tuned properly (if this is the case, saan ho? Fairview, QC ako)?
May 6th, 2005 04:23 PM #289
-tots-
sobrang budget set up yan amo.. pero pwede na yan for 25T hidni ka naman brand concious?!
May 7th, 2005 08:26 AM #290
just got my car setuped yesterday.
amp: V12 amp
Front spekers: 5" targa seps
Rear: Stock
Subs: 12" Targa Subs with PVC box
Isuzu pala makina, at least madali hanapan ng parts.
2022 Mazda BT-50 (3rd Gen)
