Page 29 of 92 FirstFirst ... 192526272829303132333979 ... LastLast
Results 281 to 290 of 918
    May 2004
    #281
    Medyo pricey nga yung bago kaya di ako makapag-upgrade, heheheh. Dun sa directed, try mo ding mag query sa kac.com. ok mga gurus dun.
    May 2004
    #282
    [QUOTE=baurtwellXUV]-tots-
    for spl po ba or sq ang set up mo?![/QUOTE]
    sir sq po. pls recommend a shop, pls. include contact details. salamat po
    Mar 2005
    #283
    -tots-
    san ba location mo para mabagy ko syo na shop na kung saan malapit sa area mo...
    May 2004
    #284
    Quote Originally Posted by baurtwellXUV
    -tots-
    fairview sir, QC shops will be fine
    Mar 2005
    #285
    -tots-
    how much will your budget for the set up?! you can go to auto circuit.. located at banawe...
    May 2004
    #286
    very limited budget 25k lang po including HU. kahit po yung pinaka-simple
    sa set-up, kasya na ba ang budget ko?
    Apr 2005
    #287
    All stock (except audio) 98 Corolla XE, midnight blue.
    Pioneer HU
    Blaupunkt IC 165 XL seps in front (6.5", 120 Watts max each, I forget RMS, 80 ata)
    Same seps on the rear
    2 Blaupunkt TSw 300 subs (12", 600 Watts max each, sealed box)
    Blue neon lights located at the rear of the subs inside the box.
    V12 NV805 amp for seps (4 CH, 2000 Watts max daw)
    V12 MRVF-450S for subs (4 CH, 3000 Watts max daw), 2 Ch lang ginamit, di pa ata brinidge
    I am guilty of buying the setup all at once without studying the subject 1st. Now that I read the threads, I think (know) I made a LOT of mistakes. I just dunno were to begin.
    Any suggestion on how to MAXIMIZE this set up OR how to improve the setup with minimal added cost (naka 30K plus napo ako) will be GREATLY appreciated.
    Thank you
    Last edited by Khellendros; May 6th, 2005 at 03:27 PM. Reason: Questions stated are for another thread...Separates
  8. #288
    1.)I know V12's max power is overstated so I don't know if the wattages (?)match.
    Probobly between 50 - 100 watts RMS.
    2.)IF, IF lang po, kasi ang mahal eh (10K), I change to Velocity seps, 350W max, do I need to change my seps amp? Nakalagay kse "500W X 4 Max Power Output" pero sa ilalim "150W/Channel RMS Continous Output * 0.5 THD (20Hz to 20KHz, both channels driven into 4ohms load)" Ano daw?
    Max output don't mean anything. Base your decision on the RMS or the continues power output. Madaming magandang seps sa market -> JBL, Infinity, Crystal, Focals, JL, etc. depending on your budget. Havn't heard of velocity tho.
    3.)I think my subs are fine, I think my seps are too weak (gumagaralgal pag malakas), I don't know if volume is too strong, the amp is too strong, or the seps are weak. (I'm hoping it's not coz I'm going deaf).
    lack of power comming from the amplifier since your using a V12 amp - its overrated. Also check your gain settings might be too high, set it somewhere in the middle para di mabilis magover heat.
    4.) Do I really need seps at the rear? I plan to sell all my seps, buy a good pair and probably reinstall the stock rear speakers. OR do I need to realize that I'm lucky enough to have aset up in the 1st place and be contended with what I have and just have it tuned properly (if this is the case, saan ho? Fairview, QC ako)?
    No, coaxials will do.
    Mar 2005
    #289
    -tots-
    sobrang budget set up yan amo.. pero pwede na yan for 25T hidni ka naman brand concious?!
    Feb 2005
    #290
    just got my car setuped yesterday.
    amp: V12 amp
    Front spekers: 5" targa seps
    Rear: Stock
    Subs: 12" Targa Subs with PVC box
What is your Car Sound Setup? (Merged Threads)
