Originally Posted by
Corolla_rider
Features
4 x 7 watts maximum power output
USB port & SD/MMC card reader
FM PLL synthesized tuner, 2-station memory
Volume/Balance Control
Radio and playback change directly
RCA line out jack
Fix panel
Specifications:
FM Tuner
Frequency Response: 87.0 – 108.0 MHz
Noise-limited sensitivity: ≤28dB
Signal-to-noise radio: ≥40dB
AM Tuner
Frequency Response: 522 ~ 1620 KHz
Noise-limited sensitivity: ≤50dB
Signal-to-noise ratio: ≥34dB
Output Power
Loud Scope range: 20-20KHz
Function
Output Power: 4 x 7 watts
Loudspeaker impedance: 4-8 ohms
Performance index supply voltage: 12V DC
The 12-month warranty on the factory battery ended a few days ago. SOH is still good at over 90%,...
