Page 48 of 307 FirstFirst ... 384445464748495051525898148 ... LastLast
Results 471 to 480 of 3070
    May 2012
    #471
    Quote Originally Posted by boogie67 View Post
    *sir jhnkvn, sir can you suggest a good 2din hu w/ a budget of 20K? TIA!
    kung may kamag anak ka sa US na magbabakasyon dito,sa kanya ka nalang pabili. you can get a 7" kenwood HU with bluetooth at <$500.kun dito mo bilhin yan nasa 40k na yan
    Aug 2010
    #472
    Quote Originally Posted by LouieLatigo View Post
    sir ask kulang kung magkano gastos sa simpleng sound setup?
    tanx
    Depends on your definition of "simple". For most, just a change in speakers is okay na. A complete speaker-amplifier-subwoofer setup could cost you around Php10,000 at the minimum though. For SQ competition purposes, a minimum budget of 60k is preferred although the only thing that's expensive in budget SQ installs is the head unit - you need a HU with time alignment capabilities at least and the cheapest one costs 10k secondhand and 16k brand-new. But for LnC and SPL applications, entry cost is much lower as long as you don't exceed more watts than your alternator gives out. In most cases, a 1000W mono amplifier and the-biggest-sub-with-big-box is enough.
    Any Pioneer AVH unit would do. Just choose one according to your needs. Cheapest one is the 1450.. and I think your budget maxes out at 3450 or 4350 Pioneer units. I'm unfamiliar with the differences sa products so just look for enough pre-outs (2 or more [more is better]) and your "wants" (ex. playback capabilities, screen size, etc.)
    Depending on your vehicle, you could also opt for those OEM integrated systems that has GPS and shiz (much like the HU of the 2011 Monty) but these aren't really my head units due to limited tuning features.
    #473
    sir, ano sa palagay mo ang magandang Pioneer AVH series na mai-recommend mo na swak sa budget na Php20-25k? mas prefer ko pala na HU yung USB and/or Ipod/Iphone ready na...
    tia!
    edited...
    Jun 2011
    #474
    Quote Originally Posted by mikomac View Post
    Here's my set-up.
    Subs: JBL GT5-S12
    Amps: X12 MRV-F805
    Coax: Pioneer 3 way 6x9 Speakers
    Seps: OEM
    Tweets: MB Quart
    Box: 40 hertz Ported Box
    I'm planning to change the seps to a Firland seps and add an another Amplifier for the voice and also changing the box for a Side Ported one to increase the pressure level of the bass and if the budget allows, will change the subs to a Ryan Audio or Firland, or Cerwin Vega, or DD and many more
    sir in one of my rides pareho tayo ng set up... pinalit ko sa stock speakers ko sa harap ay pioneer 6" full range na speakers.... parang mas may boses pa nga sa ibang seps.... like fairland.... murang mura pa.... nasa 1k lang sa raon....
    May 2012
    #475
    mga sirs may iclarify lang po ako..i own a toyota innova J. it has only 2 speakers.i plan to add 2 sa 2nd row.co axials lang sana. i've got my eyes set on an alpine co axial. bale eto po specs nya:
    RMS: 35W
    peak power: 210W
    frequency range: 30-25000HZ
    sensitivity: 92db
    ok lang po ba eto? or may ma suggest pa sila na mas maganda..
    do i still need to add an amplifier? bale yung front speakers ko,stock lang muna. i have an HU,equinox brand.aside from stock na electronics, may additional ako na 5 door central lock,alarm,led light sa spoiler and led lights sa side mirror.i also plan to add 2 headrest monitors din pala.concern ko din po kasi yung alternator ko..your inputs would be much appreciated.thanx
    Apr 2011
    #476
    Quote Originally Posted by jhnkvn View Post
    Thank you for your suggestion, i do own a 2011 montero gls but i do not like the stock HU. and i'm planning for a simple SQ but upgradable set up. thanks again sir jhnkvn!
    Apr 2011
    #477
    this is a good suggestion
    Apr 2011
    #478
    Quote Originally Posted by pong_li View Post
    this is a good suggestion!
    May 2007
    #479
    Quote Originally Posted by ecneret View Post
    tia!
    edited...
    go for Pioneer AVH P3450... got this model for 18,5K cash at Autoline... touch screen at usb and ipod/iphone ready na.
    Aug 2010
    #480
    RMS: 35W
    peak power: 210W
    sensitivity: 92db
    Okay lang po ba eto? Yes.
    May masusuggest pa sila na masmaganda. Most speakers in this price range sounds relatively the same.
    Do you need an amplifier?. No
    Alternator? Kayang kaya.
    As for the headrest monitors, I'd do it with a grain of salt. May mga kids ka ba that would be watching at the back? In 90% of people I know that has them, nagsisi sila. Buying a portable DVD might be a better alternative really.
audio set-up for beginners [continued]
