Results 1 to 10 of 30
- May 2018
- 39
December 28th, 2018 06:45 PM #1I have tried several touch up paints online pero medyo malayo pa rin with the color. Is there a shop that sells paint mix or touch paint that is exact code with your car color?
Will just use it as a touch up paint, since recently I noticed dami na small marks/scratches na macover sana with touch up paint.
December 29th, 2018 12:25 AM #2
Perhaps you can try asking your dealer. If you are in good terms with the warranty officer, it should be easy.
For slight scratches, I tried this one and somehow effective for me.
You can also check this out:
Automotive Touch Up Paint from PaintScratch - Order Pro Grade Paint - PaintScratch.com
December 29th, 2018 12:48 AM #3
Mr. Do It Colorlab. They can compu-mix based on your car's paint code & pack in aerosol cans.
- Jun 2005
- 3,774
December 29th, 2018 10:54 AM #4
December 29th, 2018 11:09 AM #5
December 29th, 2018 11:53 AM #6
I bought mine in ebay. It’s a plastic canister with a foam brush & a roller ball. The other canister is a clear coat. Cost P1,000 with free shipping from Korea. I just provided the paint code. Color exact.
- May 2018
- 39
December 29th, 2018 04:40 PM #7
December 29th, 2018 04:59 PM #8
- May 2018
- 39
January 20th, 2019 03:23 PM #9
- Mar 2010
- 2,273
January 21st, 2019 09:08 AM #10In my case Ertiga, there is a color code stamp on the passenger side, then tangalin ninyo yung gas cover then dalhin ninyo sa suking expert na pintor at siya na ang bahala.
Result was perfect.
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
