Results 1 to 10 of 49
July 5th, 2024 10:29 AM #1
What would be the minimum equipment list to have my own foamer?
I would like to stay away from using buckets altogether.
I already have a pressure washer, an air compressor (FWIW), etc.
July 5th, 2024 11:18 AM #2
are you referring to the one used by local car wash shops?
I suggest that you ask them kung saan nila binili yung gamit nila.
I once found this sa Shopee, not sure if its the same thing kasi tinigil ko na yung "DIY Car Wash At Home" project ko
https://shopee.ph/product/393825292/9664671950
Project was cancelled since the "foam device" will take up space sa garage, plus, its not that nice to look at.
Naisip ko din if Manual.
https://www.lazada.com.ph/products/f...785733155.html
pero as I said, the "project died na"
last option for me was just to use shampoo from the Chemical Guys
July 5th, 2024 01:04 PM #3
July 5th, 2024 02:04 PM #4
July 5th, 2024 02:14 PM #5
- Feb 2024
- 13
July 5th, 2024 05:28 PM #7Foam cannon attachment for your pressure washer hose. You can find cheap ones on shopee.com
The foam cannon alone will make washing way more enjoyable without buckets.
- Nov 2019
- 1,402
July 5th, 2024 07:52 PM #8
July 5th, 2024 08:53 PM #9
- Feb 2014
- 2,694
July 6th, 2024 03:05 PM #10
interesting gadget. i think i wanna try
i'm still looking for the best mini car wash setupfirst i got a 220v pressure washer. very powerful but the hoses are stiff, not very convenient
then i got an 18v washer, a lot more convenient. also got a "foam cannon" for it but the foam is very watery so it runs down quickly
so i tried those pump-up foam sprayers, foam quality is OK but needs a lot of manual pumping
Sealion 6 would be the practical choice for most people ... an entry into EV world if you don't...
BYD Sealion 6 DM-i
