Results 1 to 10 of 18
    how about those coilover sleeves type? The ones where you can use your stock shocks and are adjustable too?
    coilover sleeves? graduate na ko jan, i dont think id get those installed again, they're too damn stiff, may ngsabi get adjustable damper shocks for the sleeves pero i doubt if it will work, the shocks cant do anything if the spring itself is too stiff (well that's just my assumption, but i do think it makes sense)
    and yes you can adjust the height pero only to a limited range lalo na kung gusto mo kasing taas na ng stock ulit.
    i would suggest getting a set of lowering springs and get the branded once not the cheap copies para di msyado matigas
    if budget permits, go for full coilovers w/ adjustable height and dampers, cant go wrong w/ this
    my two cents
    Thanks for the infos bro.
    Jan 2008
    im using a lowering springs and a stock shocks,, panu ko mala2man kung sira na shocks ko?
    ^^ first, there would be some noise then check if there are oil leaks on the dampers.
    Apr 2009
    Mga sir alam ko from the grave na itong thread na ito pero matanong ko lang po, paano po malalaman at paano kapag kailangan na ng replacement ng shocks ng full coilover?
    Interested po kasi ako bumili ng branded second hand eh or surplus:
    http://www.**************/index.php/...ds=eg+coilover
    If ever busted yung shocks, pwede po bang i-Cruvenize na lang?
    Papalitin na din kasi yung shocks and springs ko eh since parang presyong surplus coilovers na din eh baka mag-ganun na lang ako.
    Okay lang po sa akin ang medyo stiff ride basta gumanda yung handling.
    up you go thread! pagpagin ko muna at nasa loob ng baul ko nahukay haha!
    with today's lowering springs and coilovers. which brands do you think is bang for the buck?
    also....has anybody installed coilovers? feedback naman ohh!
lowering spring or coilovers which is better?
