Results 1 to 10 of 14
- Sep 2006
- 3
July 26th, 2007 10:31 AM #1I tried waxing it, buffing it with MF cloth but the oily marks just wont dissapear. My ride is a black fort ergo prone to minor swirls that are easily removed by a 3M rubbing compound, but my problem is the aftermath. PLEASE HELP!!!!
TIA
July 26th, 2007 03:01 PM #2
removing swirls with a rubbing compound? that's a bit harsh.. you should have opted for a lesser abrasive product such as a polish.
- 10,620
July 26th, 2007 03:53 PM #4
Yes, hand glaze would do just right. Then follow up with Simoniz quick shine.
July 26th, 2007 05:51 PM #5
hope you haven't rubbed it too much or you would have removed too much top coat.
- Sep 2006
- 3
July 26th, 2007 08:56 PM #6Yeah, got my lesson now. Thanks guys. So whats the best thing to do with this oily spot residue from the rubbing compound?
July 26th, 2007 09:06 PM #7
sand with 2000 grit sand paper
much better if you have a buffing machine
use "Guilder rubbing compound" and kerosene
hope this works for you
Tsikot Member Rank 3
- Oct 2006
- 760
July 26th, 2007 11:33 PM #9
never do this if your not sure with what you are doing, using 2000 grit sand paper is more dangerous than rubbing compound. just bring it to your favorite detailer and they can tell what needs to be done, also you can ask them what you did wrong, and what you should have done to avoid the damage.
July 27th, 2007 08:23 AM #10
Sorry, this are just my suggestions if you can do it yourself coz ive been doing this eversince to my customers.
Using 2000 grit sand paper is a very fine kind of LIHA.. when applied to body paint in one direction with water and a bit of soap, it will remove oils and light scratches. as long as you apply it on light pressure, it will not affect the body top coat unless the topcoat is very thin..if so, repaint body top coat. Guilder rubbing compound is like a gel with very fine abrasive, unlike 3M, the texture is rough. Applying it with kerosene and a buffing machine then wax will result to a mirror like shine..
this is how they do it in most Automotive body shops if you plan taking it to detailers..
I would also do some research into the final-design-function performance of carbon fiber hoods...
Carbon fiber hood
