Results 1 to 6 of 6
- Oct 2007
- 55
August 24th, 2009 10:38 AM #1Hi guys!
Here i am again bugging you with questions... hehehe
I spray painted my crankcase top with a bosny primer and a bosny high temp. pero nag peel off siya... may hindi ba ko nagawa na naging dahilan para mag chip cya? dapat po ba may iba kong nilagay bukod sa primer? or mali ang ginamit kong paint? hmm... pls advise mga experts po... thankks talaga...
August 24th, 2009 12:41 PM #2
baka hindi mo nalinis mabuti ang parts na pinintahan mo.dapat walang oil,alikabok , malinis na malinis at dry ang parts bago mo iprimer, dapat dry na ang primer bago pintahan ng gusto mong kulay.
- Oct 2007
- 55
August 24th, 2009 06:45 PM #3Cgro nga po baka medyo basa pa yung primer
... i allowed the primer to dry lang siguro mga 20 minutes lang then i applied the high temp bosny spray.. dapat po ba ilang hours bago ko maaply yung desired color? thanks bro ha...
August 24th, 2009 06:54 PM #4
- Oct 2007
- 55
August 27th, 2009 12:32 PM #5
at least i think it is... kasi bosny primer yung ginamit ko... nagtanung ako kung may high temp na primer, wala naman daw po.. pero na repaint ko na.. di na bosny yung ginamit ko... nikko high temo naman... hehehe... so far maganda ang kinalbasan, at mas bright and glossy ang pagkared nya... let's see.. heheh
August 27th, 2009 01:50 PM #6
I use Boysen Epoxy primer with catalyst on my crankcase top as long as it is clean free from oil , grease . Mas makapit ito dahil may catalyst at pang bakal ito at hindi agad natutuklap iyong paint. Protection rin ito sa kalawang ito iyong paint na ginagamit sa grills ng mga bahay.
If purely for City driving then get the Emax7. since you already have other cars for longer drives....
BYD Sealion 6 DM-i
