Results 1 to 10 of 18
March 7th, 2016 01:09 PM #1
Currently looking for a cheap but quality buffing machine. Napapagod na kasi ako imano-mano wax yung van namin. Any suggestion? Max budget around 5k-ish. But better kung may 4k below na mapapakinabangan ng pang-matagalan. And please kindly enlightened me about this machine. Thanks in advance.
March 8th, 2016 02:45 PM #2
I saw the cheapest one at Shopwise, in the P 1700 range - orbital buffer/polisher.
I have an identical one which Walmart sells for ~$26 including tax so it would end up around P 1250.
http://www.walmart.com/ip/10-Random-...uffer/39881400
It comes with a sponge applicator bonnet and a microfiber polishing bonnet. Decent enough to give the car a good shine. I like the sponge bonnet since it spreads out the product evenly. I also find it quite efficient because the head has a non-absorbent backing which keeps the product on the sponge - I use just half a sachet of product (around 15ml) for a mid-size sedan. The microfiber bonnet is also ok, though I find I need to pat it off every now and then to remove the accumulated product and keep the fibers loose.
Am I satisfied with it? Yes. I end up using it every six weeks to reapply wax. It's cheap but I do not see the need right now to get a more upscale one. My detailing routine takes a shorter time with the polisher than without. This even if I still need to do some areas by hand since the 10-inch head cannot access them.
Is it hard to use? Put it this way - I get equally tired using the polisher as detailing manually alone. My back doesn't hurt as much using the polisher though since I do not bend over as long, but my arms get more tired because of the machine's vibration. Not sure if this is inherent to orbital buffers or if a pricier one vibrates less. But then again, I'm probably much older than youLast edited by corbon44; March 8th, 2016 at 02:48 PM.
March 8th, 2016 02:49 PM #3
My neighbor uses a non dual action polisher on his van. It seems to work. He seems to like it. He uses collinite for boats lol.
I would use a liquid wax if no polisher is used.
- Jul 2013
- 2,450
July 24th, 2016 06:33 PM #5
- Mar 2014
- 291
September 11th, 2016 09:29 PM #6Up ko lang... Im also looking for a polisher. Thanks
Sent from my SM-A510Y using Tapatalk
September 12th, 2016 07:24 AM #7
- Mar 2014
- 291
September 12th, 2016 09:27 AM #9
Matatangal ba ng polisher yung white na namuo sa hood galing sa hamog?
- Feb 2016
- 269
September 12th, 2016 11:51 AM #10Maganda ba yung sa lazada na nasa P1,200 ang price? Pang wax lang po.
Sent from my Starmobile PLAY Click using Tsikot Forums mobile app
One can only hope.
