Results 1 to 3 of 3
- Feb 2010
- 10
March 9th, 2010 08:27 PM #1I now have a 87 Dodge Omni as a project car, i had the engine removed from the engine bay have it cleaned and painted with Ace Spray paint heat resist. Steering system also pulled-out and have it cleaned also, I now have enough space to clean and paint (Primer) the corroded part of the cars chassis, engine bay etc. while I still don’t have the budget for a repaint I want to treat and primed the corroded parts a.k.a DIY.(while the corrosion is present on the surface only) Which Anzhal Primer is best to use on my application?
a. Anti Corrosion Primer Green 3370
b. Primer Surfacer Spray Filler Green 3380
c. Wash Primer
thank you and best regards.
March 12th, 2010 11:04 PM #2
- Feb 2010
- 10
Yeah, they tried with the styling but one can still see that it is not very Mazda like when...
2022 Mazda BT-50 (3rd Gen)
